Hi guys, simple question here
I'm going to get a PA 120.3 radiator, and I'm totally stuck as to where i should mount it. There is no room inside the case for a 120.3 unless i tear all of the drive bays out except one, which i'd rather not do, so it's just a question of where's the best place to mount it externally and how?
My problem is: If i bought a radbox and mounted it to the back of the case, then my monitor connections would not fit underneath, so is there a way to allow a large amount of space between the back of the PC and the rad?
Alternatively i could mount the rad to the top or side of the case, how would i go about doing this?
Here are pics of the case (mine is all black):
http://www.techpowerup.com/reviews/Apluscase/TwinEngine/3
Yes it's naff, sue me!
Thanks guys.
P.S: It would be nice for it to look pretty tidy and not that bad at the end of the day
, thanks!
Thanks guys.
