- 9 May 2009
Hi all
I just got a 3 monitor setup using windows 7 64bit and have a small problem, I have an ATI HD sapphire 5770 GFX card installed and using drivers 12.1. I have 2 monitors using dvi and 1 monitor+sapphire active dvi to displayport adaptor using a displayport, My desktop is not set to eyefinity but as 3 monitors using an extension to the desktop and have the centre monitor as the primary.
The problem is when playing videos on my desktop or any youtube videos using IE, the monitors that use DVI conections both flicker or tear the screen for a split second when loading a video up or closing it down using windows media player and the same goes for youtube in IE for a short burst but the monitor connected using the displayport does not have this effect at all its 100% fine only the 2 monitors connected using the DVI has this problem.
The videos plays fine stright after that with no problems at all its only when first loading or playing the video this happens and also when watching youtube videos in ie when the video first plays and when you shut ie down or use the back button to stop the video that it happens but the videos play fine
Now for the strange part If i open a video using windows media player it flickers or tears the desktop as it normaly does but if i leave it open on any monitor and pause the video and then open ie and go to youtube it does not flicker or tear the same if i open a 2nd video using windows media player and play the video. so it stops this problem if you have 2 videos up on the desktop but if you only have one it happens. I have also tried VLC player and XBMC and it does not do it at all even with 1 video loaded up.
i can not understand why this is happaning do you think its a driver problem i am on 12.1
has anyone herd or know what this problem is.
Does anyone know if its a driver problem and if you can downgrade the driver by just installing it over the newer versions of the driver and if so what is the most stable driver you think is best to use ? as i dont know if this is a driver problem.
thanks
thanks
