Which cooler for Ivy Bridge in a Antec P182 Case?
5 Nov 2005
Hi all
Im looking to get a new a Ivy System and not sure on which cooler to get....I can spend up to £50 if needed but have been looking at cheaper ones like these -
Corsair A50 - http://www.overclockers.co.uk/showproduct.php?prodid=HS-001-CS&groupid=701&catid=57&subcat=1395
Gelid Tranquillo - http://www.overclockers.co.uk/showproduct.php?prodid=HS-001-GD&groupid=701&catid=57&subcat=1395
Cooler Master Hyper 212 Evo - http://www.overclockers.co.uk/showproduct.php?prodid=HS-035-CM&groupid=701&catid=57&subcat=1395
These are all around £25.....should spend more and will there be any issues with my case?
Not sure if you'll be able to reach 4.5ghz with out quite a lot of heat with those coolers. But can't really say since I have no idea on what kind of heat you would actually be getting on IB anyway.
All of them are good, I'd get the Gelid as it's slightly cheaper, and the smallest at 153mm tall.
For SB, 4.5Ghz on such a cooler is quite achievable. As Ollie1132 said, can't say much about IB until it's out and reviewed :)
Ivy bridge should require less cooling compared to Sandy bridge, so any Heatsink that works on SB will be fine.
Not from what I've read in other threads.
Ivy Bridge processors seem to be toasty when overclocked.
For the same overclock you need better cooling than Sandy Bridge or with the same cooler you'll be limited to a lower overclock.
Slightly true. You should be able to achieve a max clock of 4.6-4.8 on top air coolers on Ivy Bridge (Phanteks PH14/Alphofehn K2) But your temps will probably be 75+ under load.
At the moment it looks like with the same cooler, and getting the same temperature, you can (roughly speaking) have Sandy @ 4.8GHz or Ivy at 4.5GHz which will pretty much give both processors equal performance apart from the integrated GPU.
Indeed. Which doesn't really make them worse to clock just means they are lower clock speeds for the same performance. Which theoretically is better since the vcore for a 4.5Ghz OC on a IB i5 is significantly less than the vcore of a SB i5 at 4.8Ghz.
But for roughly the same performance you're going to need roughly the same level of cooling.
Ivy doesn't appear to offer any benefit in the level of CPU cooling you can use.
That is true but they are as Dave said designed to run hotter. For me IB will be a big step up from my E6500, and if Im lucky and they release a second stepping near June then Ill get that instead of the initial release ones :) Or Ill just get a SB i7 to hold me over until Skylake.
According to screenshots I've seen the TJ max is 105C for IB, which is 7C higher than SB. So they are designed to run hotter.
It's a good job really because the indications so far are is that they do run hotter.
If you have CPU Cooler X then roughly speaking it'll get you the same level of performance with Ivy and Sandy before you run into temperature problems.
And they do seem to run a lot hotter:
http://www.xtremesystems.org/forums...e-Ivy-Bridge-3570K-vs-Sandy-Bridge-comparison.
And I was going to finally go from my ancient q9550 to the latest CPU.
15 degrees warmer on a good watercooling setup @1.3v :(
