Probably a silly question is it just water ?
You can use almost any fluid for liquid cooling once, even human blood.
It is thicker than water and does coagulate... Challenging but I don't think it's impossible with some blood thinners?You can use almost any fluid for liquid cooling once, even human blood.![]()
That's rather extreme!!You can use almost any fluid for liquid cooling once, even human blood.![]()
well that went south quick. experience?It is thicker than water and does coagulate... Challenging but I don't think it's impossible with some blood thinners?
the exacts same thoughts went through my head. blood can go rather bad after a few days. can you imagine the smell when you turn your pc on after a few days after getting back from holiday. would need to fumigate the whole house and street lol.should have mentioned that
when I had 42 syringes of enoxaparin sitting here
not just coagulation and viscosity
would be an issue
blood oxidises would go a brown colour
also a breeding ground for bacteria
would probably also smell rather unpleasant after
a while once bacteria breed
so would need some sort of additive for that too
there's been publicity stunts I believe
where they said
cooled with human blood
coolant with a couple of drops of blood
insignificant amount
was maybe for a doom promotion or something
Mental exercise... Promise.well that went south quick. experience?![]()
bit-tech.net
Nothing but asking for problem right there. do you have insurance that covers self igniting fire damage by stupidity?Pff, if you're not using a liquid sodium/potassium alloy and a magnetic pump with no moving parts are you even cooling.
*heh, it was in fact done
Danamics LMX Superleggera Cooler Review | bit-tech.net
Cooling your CPU with liquid metal sound like something from Hollywood? Think again.bit-tech.net
mayhems aurora was awful and mayhems tried so hard to get it right but had an operational life of 6 weeks. this was the reason it failed so badly and was very quickly discontinued. currently they have been working on pastel nano but not much in the news about it for a while. other versions like the xtr (first nano particle coolant for pc) was temp discontinued as it also didn't last long while in operation. 6 month operational use. 1-2 years is the norm for glycol and veg oil based coolants.I always just used distilled water with a bit of car antifreeze in it.
Had nothing but trouble with fancy fluids, Mayhems pastel was especially pants.
