Hi All,
Really noob question here.
I have just recieved my Thermal right SI 128 for my q6600.
Can anyone tell em what direction I should set the 120mm fan?
I currently have a 120mm at the front pulling air into the case over the hardrives then CPU and then another 120 at the back pulling the air out.
Do I put the heatsink fan to blow ait onto the cpu or pull away ?
I have also had the stock HS on this cpu with no thermal paste do I need to clean the chip before putting artic silver on and if so what do I clean it with.
Cheers
Shorty
Cheers
Shorty
