Hi,
Are you using the stock differential ?
~ Thom
~ Thom
Is it still badged as a 330? I think you should slap a 318 badge on there just for the lulz.
I was thinking more due to the decat. Is it straight through?I haven't noticed any drone so it can't be bad! You can hear the car more though (deeper sounding) - its more of a rumble than a constant noise though thanks to the I6. I did a section of motorway last night and didn't find myself annoyed by the sound at all.
I'm tempted to have the centre silencer removed and a straight pipe stuck in there instead but I was concerned about droning.The manifold still has the pre cats which are built in but back from that yes its straight through to the eisenmann (secondary cats and center silencer removed). Doesn't seem to make a difference in terms of droning - you're right the eisenmann has no drone compares to a lot of after market exhausts.
I have no idea what I'm talking about really.Are you talking about a general decat pipe? I've considered it on my Fiesta ST but I'm more put off by being pratted about come MOT time and the smell after a long run![]()
It's all very strict here in Belgium.
When I had the Eisenmann back box fitted, the guy said they could cut open the centre silencer(?) and stick a straight pipe through it and close it back up so it all looks kosher for the MOT![]()
Not stock, therefore MOT fail. <3 Belgium.Sounds like they just mean a decat pipe then. An awful lot of pratting about cutting it open and feeding it through, even brand new a Milltek decat is only £80 for my car so don't see why it'd be much more for yours.
It's a complete **** take, but I'm not going to derail this threadI didn't realise it was so hard to do stuff like that in Belgium![]()
