Who still has a Floppy Drive in there system........still???
I can't believe how many people use floppy disks for BIOS/VBIOS updates. Floppies are so unreliable that I'd never use them for something as "dangerous" as a BIOS/VBIOS flash, especially when modern motherboards can be flashed using a built-in flasing utility that can read from NTFS HDDs, or even from within Windows.
Floppies are so unreliable.
Proof.
For long term storage yes, but I have floppies with games on since the early nineties which still work. No CD's from that era. I also use a laptop at work which stores data on a floppy, the disks are accessed daily and we do not have failures.
For a simple boot disk, a floppy is quite suitable. You will not fit a modern bios file on one though, you need to clean boot into DOS and locate the file on your disks.
I have never personally known a mobo or card bios flash go wrong using a floppy boot and I have done well over a hundred.
As I stated above a floppy is the ONLY way to recover from a bad flash if the machine wont post or reset.
andy
