I was having major issues with overheating last night and like a prize plonker I was poking about and caught the spinning fan on the zalman VF700-CU fan fitted to a 6800GT agp card. Just the one blade has come clean off. I have found how to remove the fan but am looking for a replacement perhaps one that is quieter as the zalman fan isnt the best but did the job.
What do people suggest. Its a basic 80mm fan by the looks of things but without the standard housing and enough room at the base to fit two screws to fit the metal base to the heat sink. Can you buy direct zalman replacement fans even? If so where? Any ideas would be helpful.
Thanks
Thanks
