What are you using to measure this? I'd be keen to know temps in areas of my house without a bog standard thermometer on the wall.
Evohome, each radiator has its own thermostat. Like sticking a nest on each radiator.
I've been hovering over the buy it button on evohome for the best part of 2 years.......I just wish the trv's were better looking.
You don't have to use the trvs if your dead against them. You can use an actuator on a rad valve placed under the floor and a room stat placed anywhere you want. The actuator connects via a relay.
I'm going in investigate getting some new insulation installed. Its definitely not at the recommended depth. 27cm is it? We had the roof felted and re-tiled and the existing insulation is now covered with crud and debris. Is it worth getting rid of this old stuff, or just top up to the recommended levels with new stuff over the top of the soiled insulation?
I'll have to do a bit of investigation on the costs. I've just read about the diminishing returns you get from insulation once you get past 12cm ish.
I'm definitely looking to board out the loft, so adding new insulation may be something I do anyway to do a 'proper' job.
Still not on, not had the fire on either for the past few days.
If the old stuff is really bad then its almost like its not there, so your comparing the top up vs the full depth.
Yes its 270, but its not like 250 is terrible and 270 is awesome. The more the better, but obviously you get diminishing returns as it gets thicker and thicker
I had to do this last year as we had a very patchy 10cm depth at best in our loft. I opted to do it properly and remove all the old stuff but it wasn't a fun job. I went for the full 27cm as it was on offer and it's made a massive difference!
Cheers for the info. Where did you get the insulation from Street? I'm reading a lot about people getting it "on offer". What price should I be paying?
