- 18 Mar 2008
Really really want an enermax fan now!
Probably the reason is that they aren't really any better than anything else out there, really fan technology is not going to get much better than it is now, its not like its not been around for donkeys years.
Yes its a good cheaper option than some, but I would take all the manufacturers figures with a healthy pinch of salt as they are pretty much fantasy numbers pulled at the extreme ranges of performance.
Here specific test of the fan: http://www.xtremesystems.org/forums/showpost.php?p=4615907
Heres a whole load of fans and you can see most of them bunch together with not much margin of difference between them. From this thread: http://www.xtremesystems.org/Forums/showthread.php?t=261778
That being said, they do look very cool, esp the white ones, seen them in a few build logs.
Most of the fans are very similar but the scythe gentle typhoons are clearly 5-10dB quieter in that test for a given airflow.
I guess making a thread was worth it afterall
They haven't added any 92mm enermax fans, maybe they are still adding them, who knows.
- http://www.overclockers.co.uk/showproduct.php?prodid=FG-011-ENThey are getting them in though. Going to bag me a whole set to replace the ones in my CM690 II when they are in stock.
I had one of the magma twister 120mm's on the back on an Antec 900 and I didn't think it was that good. Sure it seemed to move a bit of air but it had a really low pitch buzzing sound whenever it was on that used to do my head in. No one else with these magmas have that?
damn it would still be nice if they designed bigger fans so i can replace the one on the front of my case.
