Will a 24" Look a Lot Bigger than a 21.5"?
Permabanned
3 Oct 2009
North Wales
As title.
I'd like a size upgrade and was wondering if a cheap 24" monitor would look a lot bigger. The 21.5 I have is a bit lost on my desk :(
My mate has a 24" 1920x1200 which looks huge but will a 1920x1080 look as big?
Thanks.
Otherwise I will get a 27" for a MAJOR difference :D
If you want a major difference go for the 27" :P depends a bit on the aspect ratio as well i.e. going from a 21.5" 16:10 panel to a 24" 16:9 panel may just result in it being a little bit wider and not actually appearing to be much bigger.
