Will a Freezer 7 take my 6600 to 3.2?
1 Dec 2002
As title suggests I would like to know if an Artic Cooling Freezer 7 Pro, will cool a 6600 enough so it can hit 3.2 gigs
prob the wrong forum but if anyone knows this weeks lottery numbers that would be great too
Noto said:
good news, ps. did you keep the standard 92mm fan that came with it?
Yeah I'm using the standard fan that came with it ;)
I posted my temps with the Freezer in another thread, I'll quote myself :D
Just got mine installed it and now just sitting at 46c on Orthos for a while @ 3.3 Ghz and that's 1.350 Vcore, IDLE's around 36-39
Stock Cooler was about 52-55 IDLE and 64-67 on Orthos.
Was even using slightly lower Vcore on while on the stock cooler which was about 1.310.
What were you using to measure temps?
@op: shoudl be fine for 3.2, I get 46c load and 33c idle with my 6300 @ 2.8ghz using an akasa amber 120mm @ 1000rpm
Raikiri said:
Then your temps are suprisingly good :) I used coretemp as TAT wouldn't work for some reason.
Pretty happy with them myself too :D
Got a 120mm fan right near the back of the Freezer, pretty nice air cycle going on there ;)
