Hi guys,
I could really do with some help. I have two 15" NEC LCD monitors which I have been happily using with dual setup on XP. No problems whatsoever. However, If I try a dual set up on Windows 7 one of the monitors goes 'out of range'. It is normally the second monitor. I know the monitors are both working fine as they both do this. I am then forced to reboot and then back to single monitor display again. Funnily enough, I had exactly the same problem with Vista (see here: http://forums.overclockers.co.uk/showthread.php?t=17761719) but turning one of the monitors down to 16 bit doesn't seem to help. I would be extremely grateful if someone could point me to a solution. It is driving me crazy! Thanks all
