Wireless lan card thats compatible with Vista 64
1 Dec 2002
Cornwall
In a moment of madness I gotmyself Vista 64 bit, it installed fine, the only trouble is my wireless lan card doesn't have any driver support so really looking for a wirleless lan card that has Vbista 64 bit support, but I suspect as long as it is supported by Vista 32 I should be fine :)
Any recomendations would be greatly received :)
That would be a great assumption to make about the 32bit drivers......if it was true! As far as I know, 64bit vista drivers are different to the 32bit ones and Vista 64 only allows signed drivers to be installed.
I've ordered a WPN 311, I spent ages looking at google and this was one of them that said it was supported on other forums, so just hoping tiw roks when I get it.
