Work upgraded PC from NT to XP - Settings.
26 Jan 2003
Nottm
Hello all,
I'm having a few niggles with my new work PC.
On NT when I copied and pasted a file from one folder to another or dragged and dropped an attachment from an email it simply put a 1 (2, 3, 4 etc) at the end of the file if it already existed. However in XP you can only overwrite. Is there a setting I can change so it will work in the same way as NT used to do? It's taking a lot longer to perform a task that I used to do in seconds with NT.
Also, when I'm executing a program, I go off and perform other tasks, when the program returns, it pops up to become the front screen, interrupting whatever I was doing in the meantime. Is there a way to prevent this?
I may find other problems as my day goes on, but overall I'm not too sure if XP is the better working environment to NT.
Cheers for any help..
Sorry, another issue I've come across that I forgot to mention above.
I've got numerous drives mapped to this PC, some located in this office, but others located in other offices around the UK.
When I open a session of windows explorer I think it refreshes the drives in the background, slowing down the PC and opening of the windows explorer window. Is this what XP does? If so, can I stop it from doing this?
On XP there's an option within Folder Options (Control Panel or Tools>Folder Options from any explorer window) under the View tab called 'Automatically search for network folders and printers' - could be this option which is causing the slowdown.
We had a similar issue in the school when I removed the old server, any mapped drives or folders on the old server that hadn't been removed would slow down anyone opening up my computer, explorer or a save/open dialog box in an application (word/excel etc).
Go through your mapped drives and ensure you can connect to them, disconnect (right click/disconnect) or bin any that you can't.
