It will fit no problem you'll just be eating into a bit of your cable management space.
As RJC mentioned I'd only use 2 Ti's if you plan to put them under water.
If you do want to run them on air however we are working on a solution for a forum member to add around 30mm extra in a double layer type of internal case feet. That way we can use the 2 x 120mm fan base plate you may have seen on this forum.
Let me know if thats something your interested in.
