WOW! A use for my 350D SLR!
22 Jun 2005
Nottinghamshire
OK my dad has around 3000 items that need photographing.
this is the kinda stuff that needs photos taken of.
What can we do to do this? I was thinking of a light tent with those lights that you get on ebay for around £80
Any other reccomendations, the potential flaw I have noticed with a tent is that I need to take photos from directly above the item, how is that achieved using a light tent?
Thanks for your help!!
jamoor said:
how do you get a tripod into a light tent exactly?
A tripod with a centre column that can be mounted horizontally could be helpful in this case, allowing you to have the camera to be positioned easily over the tent.
eg:
3000 different items OoOoOoOoOo
how many photos are you gonna be taking man :eek:
i would say shoot jpeg, at least 3000 raw files are gonna take some shifting
mrgubby said:
Get one of these from a high street electronics/hobby shop.
They give pretty good results :)
or make your own from a few bit of white card, and some old grey/blue cloth. Mind you if those little cages are cheap, then buy one.
If I had around 3000 similar shots to take, I would definately use a tripod, pre-focus with enough DoF to capture it all and use a cable release. Using studio equipment or a tent I think would be overkill, just arrange some white card to give a nice walled box, and bounce a flash into the box from above. Take test shots to get exposure sorted, and Bobs your uncle.
I wouldn't fancy taking all those shots mind, I once did about 100 shots it took far longer than I wanted it too, and you have 3000. Jpeg will be fine, processing 3000 RAW's will take soe time, even if you use a load of batch actions.
Oh most importantly, get some rechargable batteries for your flashgun...
Its made from cloth so light shines through the sides for that nice soft glow/low shadow effect
mrgubby said:
google for 'Portable Soft Lighting Studio'
I just googled it and will probably get one.
From the same place, you can buy Mobile Phone camera tripods!! :eek: :D
(just kinda tickled me!)
eg:
Which Manfrotto tripod is that AdWright? That looks pretty cool and I would probably love to get one and experiment when I get my 350D. How much are we talking in general for this?
Yeah, at work I've got a £25ish one from eBay (they've gone down a lot recently it seems). Defuses the light apparantly, certainly better than shooting on a table or something.
I'm still trying to convince them to buy some daylight flash bulbs (£180 ish for two, shop around) as lighting conditions can be a pain. I generally use the custom white balance feature and/or tweak the colour temperature in software.
Not sure, just googled for Manfrotto. However, I have the 190ProB, which is very versatile (removable centre column that can be mounted sideways as well, really low minimum height etc) which cost £89 for the legs. Then you'll need to add a head appropriate to your use. I have a ball head (484RC2) which has a useful quick release plate. The head cost about £39
Thanks for that AdWright, just had a quick look at one photography site and think I've found it. Will check out some other sites later on.
