Hi, just got a 360 and a vga cable to use with my dell 2005fpw, if I set the res anything than 1280X720 - the games have the wrong aspect ratio but if I use that res the screen has a white tint! I'm running at 1366X768 and the aspect ratio of the menus are fine just the games.
I've tried running all settings, aspect, fill, 1:1 but all have the wrong aspect ratio unless 1280X720 how can I fix this problem and get the right aspect ratio for my 360?
) just seems v.strange
check the pins on the vga plug. check d/board resolution? do auto adjust on tv once loaded up, on mine i can adjust height and vertical independantly, see if you can do that.
Just position which is automatic and perfect.
