ok i have logitech z-5500 have my pc ps3 connected fine, also have my 360 connected but its using optical like ps3 so switching them all the time is a pain. now i know i can get a optical switch box but i cant even be arsed switching that all the time.
on the logitech control pod i have a digital coax connector doing nowt, then i see this mod check it http://www.warnockinc.com/www/?q=node/18
now what puzzles me is the last four pics, well forget the last one the three before. now im pretty sure i can hack the 360 optical dongle and get the two optical wires(signal and ground out) what im miffed about is that red rca/coax style connector with the two wires coming out. i need this!! now its not a rca lead because i have some and theres only one wire with rca leads, its not coax either because the mid coax wire is solid copper and the pic shows normal type wires.
also can you see the pic where its all joined up with some kind of adapter? well i have this in mind will it work? http://cgi.ebay.co.uk/2-x-RCA-Phono...uting_CablesConnectors_RL?hash=item5184bebfad
thanks
thanks
