Looking at the Zalman site the VF900-CU comes with the memory heatsinks so you won't have to purchase them.
To be honest I don't know if it matters that your card only has two screw holes instead of four. However as long as the heatsink is secured down by at least two screws it should be fine I would have thought. I also doubt that Zalman would claim that it is compatible with your card if it really wasn't. Should be fine.
Have the xxx version of your card, also have a vf900 sat on it, reduced my idle and load temps by 15 degrees mate... definately worth it, stick the fanmate on it and it runs stupidly quiet too
