- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Hey guys,
We have received delivery of the XFX XXX and Black Edition PSUs after the whole channel has been out of stock. With 80 Plus Silver certification these PSUs will give you exactly what you need to keep your gaming charged and ready.
XFX 650W XXX Edition Modular Power Supply @ £74.99 inc VAT
Designed specifically for the high performance gamer, the XXX Edition PSU supports multiple high-end graphics cards. Offering an array of unparalleled features, and delivers exceptional performance. One of the main key features is the presence of four connectors for video cards, allowing you to install two video cards that require two power connectors each. Some 650 W power supplies from other manufacturers have only two of them, and some users only discover this when it is too late (i.e. after buying a second video card and trying to install it).
- Tight voltage regulation (±3%)
- High power efficiency rating
- High quality Japanese brand capacitors (105°C)
- Ultra slient ball bearing fan provides quiet and superior cooling
- Supports multiple high-end graphic adapters in NVIDIA SLI or ATI CrossFire
- Supports the latest ATX12V and EPS12V standards
- Active PFC with Universal AC input
- Detachable modular cables
- Energy Star 4.0 and RoHS compliant
- 5-year Limited Warranty
Only £74.99 inc VAT.
ORDER NOW
XFX 750W Black Edition Modular Power Supply @ £92.99 inc VAT
The XFX Black Edition 750 watt modular power supply gives you the power you need with a brilliant
combination of form and function. Giving more than just life to your PC, this power supply allows easy cable management with modular connectors which helps increase airflow. With tight voltage regulation and high efficiency operation up to 88% (80 Plus Silver) this power supply will give you exactly what you need to keep your gaming charged and ready.
-750W of continuous power at 50°C
- High efficiency operation up to 88% (80 Plus Silver)
- Single, high power +12V rail (up to 62A/744W)
- DC to DC voltage Regulator modules for +3.3V and +5V
- Solid polymer caps provide enhanced reliability and stability
- Quiet 135mm ball bearing fan provides superior cooling
- Supports multiple high-end graphic adapters (NVIDIA SLI & ATI CrossFire Ready)
- 5-Year Limited Warranty, subject to registration
Only £92.99 inc VAT.
ORDER NOW
XFX 850W Black Edition Modular Power Supply @ £116.99 inc VAT
The XFX Black Edition 850 watt modular power supply gives you the power you need with a brilliant combination of form and function. Giving more than just life to your PC, this power supply allows easy cable management with modular connectors which helps increase airflow. With tight voltage regulation and high efficiency operation up to 88% (80 Plus Silver) this power supply will give you exactly what you need to keep your gaming charged and ready.
- 850W of continuous power at 50°C
- 80 Plus Silver Rating
- SLI Ready
- Detachable Modular Cables
- Single, high power +12V rail (up to 70A/840W)
- DC to DC Voltage Regulator modules for +3.3V and +5V
- Supports multiple high-end graphic cards (SLI & CrossFire)
- Active Power Factor Correction
Only £116.99 inc VAT.
ORDER NOW
ORDER NOW
ORDER NOW
- SLI Ready
ORDER NOW
