XONAR DX - CRACKLY and one speaker :( - help !!!
7 Jan 2011
Reading , UK
hey all
could do with some help getting me new PCI-E Xonar Dx working
Win7 64 bit
Asus p8p67 mobo - onboard
It is installed in PCI-E ( 2 beneath graphics) - and floppy powered correctly from molex
windows detects ahrdware. have downlaoded the latest driver set for win7 64. it runs through install and then restarts
sound only comes through left speaker on 2.1 setup and there is a lot of crackling from the other speakers :(
what esle should i be looking for ?
You could try reseating the card, also make sure the power connector is inserted as fully as possible. If that does not improve things, you could try installing the drivers again, but uninstall them first.
If you still have no luck, then a faulty card is a possibility. There is a chance being so close to GFX cards would cause some interference, however it's unlikely that would result in sound from left only, and not right.
i am sure the card is in fully and likewise with the power - speakers are fine as i have teseted with onboard.
uninstalled and tried installing the setup it got to 99 % then message
please plug in asus xonar audio device!
restarted machine
same cracking sound from one channel and device manager has device listed there but no asus sound client installed - this must be where it broke. going to google but wanted to provide an update
yeah will try another slot now
i have tried just installing the driver direct from device manger rather then the .exe same result
will swap slots now to furthest away from graphics card
*STOKED* ALL FIXED - THIS SOUNDS PORNO
OMFG this sounds schweet - paired with acoustic energy aego m 2.1
the old addage is true - assume nothing and go back to the beginning when all seems lost
deleted everything - reset the card made sure it was screwed in tight , double check all connections
added the latest driver for win 64 .
configured speakers in windows - checked settings in asus client and bingo
