** YO DAWG, I HEARD YOU LIKE MODULAR **
OcUK Staff
26 Nov 2014
Stoke
So I've put modular on your wired, so you can be modular while you wire.
Superflower Golden Green HX 750W's are now Semi-Modular, and as we love to give you a deal, we've swallowed the price increase too to avoid raising the price! Grab yours now.
SuperFlower Golden Green HX 750W "80 Plus Gold" Semi-Modular Power Supply - Black @ £82.99 inc VAT
The Golden Green HX series are the perfect all rounder. They meet 80+ Gold Standards resulting in lower electricity usage, saving on the bills, hence the green. The Gold Rating means they are capable of powering pretty much any PC specification and the 14cm fan ensures the PSU stays cool whilst remaining quiet. One of our best value for money Gold Rated power supplies we sell.
Features
- Supports all Intel and AMD Dual Core and Quad core and its compatible Motherboards, ATX/BTX compliant.
- Supports Intel Core i7-980X / Core i7 / Core i5 / Core 2 Quad / Core 2 Duo &AMD Phenom II X6 / Phenom II X4 / Phenom II X3 / Athlon 64 X2series chip set.
- EPS 12V Ver2.92
- Semi Modular
- Patent black color connector, easy plug-in design, safe and firmly attached.
- Fit in with EuP(Energy-using Products) instructions / U.S.A Energy Star standards: energy consumption during shut off status less than 1W
- PCI-E power plugs are setup in a 6+2 configuration for the latest graphic cards and Compatible with every brand.
- Patent 12cm Low Noise Fan, Great air flow for exceptional heat dissipation.
- Passed 80 PLUS® Gold Certification, on 20% 50% 100% loading, with 91.64% 92.88% 90.99% Transform Efficiency.
- Full Range APFC, support 100V~250V.
- Patent high power and low consumption transformer / Patent dual voltage circuit with intelligence thermal control system (Patent applying for U.S.A, Taiwan, Mainland China and other countries)
- Solid state Capacitance is used for longer lasting and higher reliability.
- Extend Output Capacitance are used for higher stability and longer lasting.
- Over Voltage Protection / Over Current Protection / Over Power Protection / Short Circuit Protection / Under Voltage Protection
- Switches on/off test for more than 2000 times.
- Multiple safety certificates acquired.
- All series are made of RoHS unleaded green material.
Specification
- Real Power: 750W
- Transform Efficiency: on 20% 50% 100% loading, with 88.77% 92.82% 88.61% Transform Efficiency
- Intel Power Design Guide: EPS Ver. 2.92
- Outlook: Honeycomb ventilation panel, high efficiency air flow design
- Fan Size: 12cm Silent Fan with temperature control
- Dimension: 145mm(L) x 150mm(W) x 86mm(H)
- Protection: OVP/OCP/OPP/SCP/UVP
- Safety Certificates: BSMI R33529 / CE / FCC / CUL / cTUVus / CB
Connectors
- 1 x 20+4-Pin ATX12V/EPS12V
- 1 x 8-Pin EPS12V
- 1 x 4+4-Pin ATX12V/EPS12V
- 4 x 6+2-Pin-PCIe
- 8 x SATA
- 4 x 4-Pin-Molex
- Warranty: 5yr
Only £82.99 inc VAT.
ORDER NOW
About time too, I have been on about these for ages. What about the smaller units as these go down to 550w. That's what OCUK is lacking in, smaller capacity modular psu's. These are a nice alternative to the Leadex units if you don't like the led's.
***Edit*** Just seen that these have a blue led fan. Why can't they just give us a plain psu without tacky bling?
Regarding the lower modular units, they are in the pipeline, this is the first one to make it out of the factory. On the subject of the LED fan, that's my bad, it actually comes with a 12cm black fan, I've amended the spec and forum post to reflect this :)
I am looking forward to the lower end modular PSU, and without "tacky bling" it will be first on my shopping list.
Excellent on both accounts. :)
These are different than the units on Superflowers website then as they do have a blue led fan? Do they still have a single 12v rail of 726w?
Got a question regarding SuperFlower PSU's. Do they not include an adapter to change to the UK style plug? My 850W came with a 2 pin like shown in the pictures of the product.
They should come with UK cable as standard. If you can inform CS they should be able to send you a UK cable out.
Yep, they are the same spec, as far as I am aware, they have never came with LED fans and I will amend our specs to confirm.
I thought it seemed a little odd, thank you. I've left them a message in the CS forum.
Luckily I have an plug adapter I can plug this into for now, although it isn't an ideal solution. At least it will let me know if my computer works once build.
I thought ocuk provided a seperate kettle lead with all purchased SF psus. My leadex gold had a euro plug in its box but a seperate uk kettle lead was sent with it.
Always been hit and miss for me, I've taken to keeping a few spare leads and adapters.
I got a 2-pin cable with a 550W Superflower PSU I bought recently, but didn't really need to mention it as have plenty of spare UK leads around anyway :p
I'm heading to OCUK on Saturday! A little road trip with my little sister.
Let's see what you've got!
