Wish I went for this board after seeing this. Any personal photos of the board? curious to see the LED's.
I think it looks good, so much better than that dodgey gun barrel heatsink. Still no PCI slot which imo should have 1 instead of so many small PCI-E that no one would use anyway on this kind of board.
But the problem is no matter how good the motherboard is...IvyBridge i5/i7 CPUs would turn into a micro-oven and temp becomes too high for comfort to use 24/7 when overclocked to 4.8GHz and beyond (and having better CPU cooler doesn't help much due to how the chip is trapping the heat inside itself)...the limiting factor of the CPU is really with the temp, rather then if a motherboard can push IvyBridge i5/i7 beyond 5GHz or not...
Dual Channel, although you will be able to run four sticks of ram no problem. Quad Channel = X79.Skunkworks said:Does this use quad channel mem?
M'mm that motherboard setup looks really hot!
Yes....yes she does![]()
Ah, I see, thanks.Dual Channel, although you will be able to run four sticks of ram no problem. Quad Channel = X79.
