zeon motherboard 2x 8pin 12v connectors
18 Oct 2002
Kidderminster
Hi,
looking at getting a motherboard secondhand comes with two xoen 2.0ghz chips on it. I'm strugagling to find a PSU to power the board as it has 2 * 8pin 12v power connectors. I've not been able to find a PSU with 2 * 8pin connectors the ones overclockers do all have 1 *8 pin power connector.
So does the board require 2 * 8pin connectors or just one and they put two on to giver you a choice?
The board is an iwill dxp.
Any thought / help would be much appreciated.
cheers
Deano
Hi
sorted now do require 2 * 8pin connectors :(
Heading over to the wanred forum now :D
Deano
Indeed i believe the two are required...as you stated :)
Erm, If its possible to buy Supermicro Psu from retailers then some of them have two 8 pin connectors.
Trying to think what PSU's we use at work with out Iwill systems but my memory's blank... :(
