Zotac 3090 power requirement
14 Sep 2011
Hi all just upgraded to a Zotac 3090 from 2080ti. I'm unsure of correct power cables, my 2080ti had just one cable with two 8pin plugs. Can I just use this for the 3090 or do I need to plug just one of the 8 pins in and install a second cable for the other eight pin, I'm assuming the single cable doesn't provide enough power. Many thanks Paul
16 Feb 2004
London
yeah the zotac can pull 350w, you'll get about 60-70w from the pcie connector and the rest split on the PSU cables. You can feel them getting warm on full load
