A couple of weeks ago when playing FC5 i noticed the below noise coming from my card.
https://www.youtube.com/watch?v=umGmar_p8ek&feature=youtu.be
Upon looking into the issue. I've noticed it seems happen as the load progresses on the card. Once its peaked the noise stops. Same happens also when idling, it will make the noise then it will die off when idle.
I've tried the following steps also
After the card was returned to me, its back in my rig now - again still makes the above noise when the load is progressing and vice versa.
I'm completely stumped as to what this issue could be? It's also very annoying hearing that noise when gaming.
My spec is as follows,
8700K @ 4.7
Aorus Gaming 7
Team Group Dark Pro 16GB 3200
Zotac GTX 1080Ti AMP Extreme Core Edition.
Superflower Leadex Platinum 1000W
Also to note the card is at factory overclock.
Cheers
- Blowing out any dust and re-seating.
- Tried a different PCi-E power cable.
- Ran DDU and installed latest drives.
8700K @ 4.7
Aorus Gaming 7
Cheers
