Zotac gtx560ti 488 temp
How could it be the cooler, do u mean it could be seated improperly or not screwed down tight enough.
thanks for all the help aswell, i dnt no were id be without this forum :-)
got my new 570 today (while my 580 is in for repair) and it idles around 35, full load 65-68. The 560ti 448 is the same board and chip with some gubbinses disabled. Mine is however a MSi Twinfrozr iii Power Edition (factory overclocked)
Is th 570 twinfroz quiet?
How could it be the cooler, do u mean it could be seated improperly or not screwed down tight enough. /QUOTE]
It might be a case of a cooler not making proper contact with the chip
it's supposed to be until it reaches high temps
found something very strange out , if i just have my main 23 in lg monitor plugged in via dvi on its own the temps are as they should be (to be precise they are 4 degrees higher than normal), but if i have my samsung 32inch tv plugged in via the a hdmi cable or a dvi cable (tried both) at the same time the temps go up an extra 20 -25c, im stumped, any no y this is happening?
http://www.overclock.net/t/964370/fix-info-dual-monitor-downclocking-fix-for-nvidia-cards
Im sure this issue has been fixed in the latest drivers from Nvidia, try the latest from their site.
http://www.nvidia.co.uk/Download/indexsg.aspx?lang=en-uk
does any1 else get ran out of memory on your gpu message on battlefield, i guess ill just have to use high settings instead of ultra, unless there is a fix
i have the latest drivers installed - GeForce 296.10, so is it a fault with the drivers then, i just searched nvidia for better drivers and found these GeForce 295.51 Driver should i try these?
i have a crucial m4 64gb and turned the paging file down to 200mb so it isnt turned off, ill change it to 4g and try that, im sure its to do with gpu vram though
