Watercooled Case Gallery
Permabanned
22 Jun 2005
Westbury, Wiltshire
Heres my baby during the build stage! :)
PC:
Coolermaster Cosmos S
IP35 Pro Motherboard
Intel Core Duo e8500 (E0)
2GB Corsair Dominator RAM
74GB Raptor HDD
Nvidia 9800x2 GPU
700W Thermaltalke PSU
UV Cathode due Saturday! Will light up beautifully
Watercooling:
Laing D5 Pump
XSPC CPU Block
XSPC Res
XSPC Triple RAD
Xilence 120mm fans
3/8" Tubing
CPU currently clocked to 4.4ghz @ 1.46v (BIOS) and ORTHOS stable. Temps are very good, 52 degress is the highest Ive seen it go! I had the preperation done by another onine retailer. Wasnt too expensive either.
16 Jun 2007
London
dude that practially my new build :O
:D
just waiting for an RMA on the 120.3 but else its built.
120.3
GTZ
4870x2
but i have a Q9550
i only have 4GB of geil
be quiet 650W (im guessing yours is 750W though)
cable managment holes :D
asus maximus formula II (not I as yours)
24 Mar 2008
High Wycombe
Another vote for sticky - forgot this thread was still on here :D
Will get some updated pics of my PC on here later though looking to upgrade my case to a TJ-07 with some new goodies :)
rjk
rjk
Caporegime
8 Aug 2007
*rjkoneill posts his rubbish case up and assures forum members that he will have his Silverstone FT01B-W soon*
this is a jeantech aqua - officially the crappest case ever
spec is:
ocz hydroflow block
xspc bay res/pump
tfc Xchanger radiator 120mm
sharkoon silent eagle 2000 120mm fan
dtek - 1/2" hose tails
masterkleer tubing 7/16"
primochill coils
Feser Pure Water
came to about £110
much better than any kit!
28 Mar 2007
As soon as I got my TJ07 I was going for some powder coating but after a threat by the misses of some appendage removal I had a rethink. At this stage I did not want to go cutting holes into the case yet untill I upgrade Nehalem when it matures. So not my original idea but Inspired by the Dark Water build of a clean way of hiding all those cables etc, here is my imitation I suppose.
Specs:
TJ07B-W,Kaze Master BLK FAN Controller, SilverStone CFP52B Cooling front Panel with Thermaltake Cyclo pattern fan and Scythe Hard Drive Stabiliser due to a bit of a tight squeeze to use the CFP52B
Asus commando
E8500
OCZ 9200 Flex I (they have the copper channels inside)
Nvidia 8800GTX
x1WD1500HLFS for OS, x2 WD6400AAKS one for games and other for music and films etc, x1 diamondmax 17 for OS image and x1 External Maxtor for 2nd line backups
XSPC Dual 750, TFC Xchanger 480, Swiftech Apogee GTZ, all other blocks EK, tubing XSPC 7/16 UV Clear Blue and 6mm, fittings EK and Alphacool just need some uv red antikink coils.
Temps at stock CPU 34c and GPU 40c with water temp 23c in warm room. CPU high 30's to just over 40c and GPU just over 50c after gaming for after 3 hours and during 3DM06. Just waiting for AS5 to bed in before OC.
picture.php
picture.php
picture.php
picture.php
picture.php
picture.php
