i just got dead space 2 but i'm so disappointed
OP
24 Jan 2007
I know they are expensive but have you thought about a head pointer ?
Or there is that Integramouse thing which you control with your mouth, but i think that's £1000+ !!
using it with my mouth won't be any good as i can't control my mouth to well.
head pointer i will look in too
thanks
30 Sep 2008
Chelmsford
Ive never thought about this before must take incredible skill to control games using the method you described.
As for Dead Space i just don't know how you could control it im playing the first one (in preparation of the second getting cheap on Steam) and it uses every single button on the controller??
8 Oct 2008
There re some nice 3rd Party solutions that should make the way you currently play no problem.
This free software looks like exaclty what your after.
http://www.highrez.co.uk/downloads/XMouseButtonControl.htm
If you are really bored, and fancy some scripting you can try Autohotkey.
OP
24 Jan 2007
24 Oct 2005
North East
Using noclip thats cheating :p
Ah well least u can look and move how does firing and turning accuratly go?
Also whats with all the artifacting in the game?
Ah seems it was the crysis vid i saw, dont think it was latest one. :p
Edit - Fo3, not bad man :) Can u switch weapons ok or is that usually a hassle?
OP
24 Jan 2007
no artifacting , it's the capture program quality is poor
