*** Amazing OcUK Corsair 900D Build ***
8 Sep 2003
150 yds from OcUK
We at OCUK where very lucky to recieve a sample 900D Case from Corsair and wanted to show off exactly what this case is all about for our Valued forum members and Customers.
Build Spec
3930K
ASUS RIVE
Corsair 1866mhz Dom Plats
MSI 7970 Lightening Boost editions x3
Corsair 1200w PSU n( with Braided Cables Kit)
Corsair Neutron HDD x2 (RAID0)
Watercooling
EK RIVE and Supremacy Blocks
EK MSI 7970 Lightening Water Blocks
SRI 480,360,240 and 120 Rads
2 x XSPC Bay res with 2.2 pumps for dual loop configuration.
Corsair SP series 1450 RPM fans ( Silent but powerful and look good too)
EK and Bits Power Fittings
Mayhems Coolant Pastel Black and Pastel Red.
Parts Laid out!!
We then blocked up the CPU, GPU and MB.
and striped out all the drive bays from this huge case!! The feature list and cooling options are endless.
The PSU, Quad and Dual Rads in the base of the case for Graphics and Triple plus single in the roof and extract 12cm fan!! Yes plenty of room for RADS with all mounts provided and no modding. As we went with two Bay pump combos a quad on the roof proved impossible but it certainly is an option for other configs. We had 4x120 Rad area anyway for CPU/MB which is enough in any ones book.
Tubing up the board, Pumps and rads.
Ready for the board.
Board in and CPU/MB Loop Filled. Leak testing.This gives you an Idea of size of the Case even RIVE looks small.
GPU's in.
GPU Loop fill and bleed.
Cablemanagement which was easy with all the options for cabling and drive bays needed installed.
Does it post??? Yeah man!!
Completed Build.
Overclocking with great temps was easy to 4.7ghz on CPU and GPU's at 1200/1750
Temps on CPU where around 65C on hottest core under prime load.GPU's after hours on Unigine where mid 40's.
Benches.
All in all a great looking and performing build in a really high end builder friendly case.
24 Jan 2008
Londinuim
great build but...personally I don’t like how it looks with two reservoirs at the front...especially with black one on top..
or maybe it is a fault of missing bits of front panel to sides of reservoirs ?
if all would match case finish, maybe it wouldn't look so off - for me.
