**THE NVIDIA DRIVERS THREAD**
22 May 2010
Minibotpc
Are they.... Safe
Im sceptical after the last drivers causing artifacts in some recent game titles. Reverted back and all is well again.
I noticed the latest drivers drop the core voltage from 1.175 to 1.15 in evga precision x.
Man of Honour
13 Oct 2006
New official ones _should_ be available late Monday night. I'm not sure they are that different from 320.18 tho (other than fixes for corrupt rendering in some games).
14 Jun 2008
Seems Tombraider has had some work done on it.
I did a few tests @1440p with everything set as high as possible:
FXAA
2xAA
4xAA
Spec:
Don't forget chaps, apparently Nvidia is rubbish at non CUDA compute. ;)
Caporegime
12 Jul 2007
United Kingdom
FXAA
2xAA
4xAA
Spec:
I don't think anyone ever questioned a titan's compute performance Layte. But seeing as you mentioned it, here's a little comparison for you.
Copied your settings exactly, 7950 crossfire 27% behind at 1440p with FXAA and AAx2. Not bad i think you'll agree for two cards costing 300% less, assuming you paid at most, £800 per Titan. ;)
FXAA
x2 AA
14 Jun 2008
You forgot 4xAA :)
Also, serious question, did you manually set the shadow quality to Ultra? I notice when you set the preset to ultimate it does not max out the shadow setting which is strange.
Caporegime
12 Jul 2007
United Kingdom
You forgot 4xAA :)
Yes i didn't bother with x4, though as both results (fxaa and x2) were 27% i don't see any reason why x4 would be much different, and yes shadows were on Ultra, i copied your settings. :)
