Catzilla 1.0 Benchmark Scores
5 Sep 2011
Surrey
Here you go Nick
4960 @ 4750(Water) (125 strap)
Dom Plat 2000
780Ti Ref SC (Water) @ 1316 / 3910
Like I say, clutching at straws :p
12 Jan 2014
Is it just me or does this scale horrible (even negatively in some cases) with multiple cards? I disabled one card and I got a much better score than with my dual card setup:
Catzilla 720p benchmark
EVGA 780TI Classified KPE 1285/1850
i7 4770k at 4.5 GHz
I will overclock this one card further and see but so far I am pretty disappointed by the benchmark.
19 Jun 2004
n/east-the toon
Good day Kaaps, my Catzilla score's for 1 GPU-670:1358/3490+CPU 4820K:4.6GHz
720p=14412 / 576p=17778
My 670's are not doing to bad when looking at my score's, l'll try to get a touch more from my 4820K.
I think 4.750GHz was my best when testing my 4820K's limit without silly volts > 4.8GHz>1.5v. lol:D
Thanks,
Chris.:)
Man of Honour
OP
21 May 2012
Dalek flagship
Thanks,
Chris.:)
And on the scoreboard sir.:)
15 May 2012
Louth, lincs
Thanks,
Chris.:)
run dual chanel ram(take a stick out each side if running 4, check manual for running dual) and turn hyperthreading off to clock higher, on my other 4930 managed another 200hz which helped no end on this bench
19 Jun 2004
n/east-the toon
Cheer's for that Nickolp1974 my PC H2o cooled is due a monthly check > water level etc and clean fans/filters/rad, will do it then and post the results.
