Caporegime
- 21 Jun 2006
*********** WORK IN PROGRESS *************
A lot of the info has been taken from this thread
http://www.head-fi.org/t/534479/mad...e-4-17-2014-akg-k612-and-k712-pro-added-edits
TOP CHOICES (for quick reference)
Guide:
Green = Amp not needed
Orange = Benefits from an Amp
Red = Amp is essential
Competitive (Main Use - FPS Gaming):
<£50
£50-£100
AD700 - second hand only
HD 595 - second hand only
£100-£150
AD700x - newer version of AD700
PC360 - built in mic
HD598
K612 Pro
£150-£200
K701
Q701
>£200
SRH1840
SR-407
ESP-950
Fun (Main Use: Movies/Music):
<£50
HTF600
£50-£100
£100-£150
£150-£200
Fidelio X1 - Compatible with V Moda Boom Pro
>£200
MDR MA900
D7000
LCD-2
DT990
Mad Dog v.3.2
HE-400
Alpha Dog
K702 65th Anniversary Edition
K712 Pro
All-rounders (for both uses):
<£50
Koss Porta Pro
Koss KSC75
HD201
Creative Aurvana Live
£50-£100
Creative Aurvana Live 2
£100-£150
DT770
AKG K612 PRO
£150-£200
>£200
D7000
LCD-2
Alpha Dog
HE-400
K712 Pro
MrSpeakers Mad Dog v.3.2
DT990
ESP-950
Microphones
DX Clip on Mic - £1.50 delivered (2 week lead time)
Speedlink Spes Clip-On Microphone - £8
Both the above mics are very very good no need to buy anything more expensive unless you fancy an all in one like the v moda boom pro or are a streamer, then you can look into more expensive options of your own accord the above are more than enough for the average gamer.
Why are Gaming Headsets often said to be inferior to regular headphones?
In general, headphones (especially "audiophile" or "hi-fi" headphones) tend to have better sound quality than your typical gaming headsets. This is due to a number of reasons, such as: a design more focused on maximizing sound quality instead of maximizing stylish "gaming" looks, an Open Vs. Closed design (most gaming headsets are closed), and simply having more experience at designing headphones than gaming headset companies.
What about multi-driver "true surround sound" headphones? Aren't they better?
No. Multi-driver headphones make use of tiny drivers with inferior performance to larger stereo (dual driver) headphones. A better route is a good pair of stereo headphones with a good virtual surround DSP.
Do I need an amp?
That depends on your headphone. All headphones will benefit from an amp, but some benefit more. Those are usually higher ohm OR lower sensitivity headphones.
Will headphone X be a huge improvemet for competitve gaming over the AD700?
Probably not. HD800s or SR009 are probably the very best headphones, but nothing is going to be that much of an improvement for competitive gaming over the AD700s.
Your NOT going to keep getting competitive improvements as you go up in price. The main improvements your going to get are a more immersive sound (fuller weighter sound, better bass). Sometimes a more immersive sound counteracts a competitive focused sound though. Part of the reason the AD700 works so well for soundwhoring is because it sounds bright and bass light (counteracts immersion though).
So if your looking for the very best headphone for competitve gaming, just get an AD700. Or get an HD800. Everything in between the two will offer improvements to immersion, but not really improvements for simple competitive sound whoring. If your willing to trade a little competitive ability for a more immersive and enjoyable sound (and a more audiophile headphone that will be better with music), then you should look at more immersive headphones.
What traits make for a good competitive gaming headphone?
A non-bassy heavy signature, emphasis on mids and highs to bring out details like footsteps, and a large and accurate sounding soundstage...
What traits make for a good immersive gaming headphone?
Dat Bass...
Should I get a mixamp if I'm gaming on PC?
No, probably not. Devices like the Mixamp are mainly recommended for consoles. For PC's a better solution is an internal soundcard.
Guide:
<£50
£50-£100
£100-£150
HD598
K612 Pro
£150-£200
K701
Q701
>£200
SRH1840
SR-407
ESP-950
<£50
HTF600
£50-£100
£100-£150
£150-£200
>£200
MDR MA900
D7000
LCD-2
DT990
Mad Dog v.3.2
HE-400
Alpha Dog
K712 Pro
<£50
Koss Porta Pro
Koss KSC75
HD201
£50-£100
£100-£150
DT770
AKG K612 PRO
£150-£200
>£200
D7000
LCD-2
Alpha Dog
HE-400
K712 Pro
DT990
ESP-950
Microphones
Do I need an amp?
Dat Bass...
