Sniper Elite V3 Benchmark
23 Dec 2013
North Wales
Dual 280X @1110/1575
FX-8320 @4.5
14.9.2 Drivers
DX11
1080p
Sniper Elite 3 Benchmark Report (DirectX)
Created: 2014-11-01 at 03:59:42
Version 1.14 Build Version: 2014.10.29.004
Average FPS: 79.8
Minimum FPS: 11.0
Maximum FPS: 377.5
Number Of Frames: 6067
Average Frame: 12.538ms
Minimum Frame: 2.649ms
Maximum Frame: 90.536ms
Machine Name: BENW-PC
Monitors: 1
Operating System: Windows 8 Professional (build 9200), 64-bit
System RAM: 8107MB
CPU: AMD FX(tm)-8320 Eight-Core Processor
Number of Cores: 8
GPU Name: AMD Radeon R9 200 Series
Feature Level: DX11.0
Dedicated VRAM: 3072MB
Resolution Width: 1920
Resolution Height: 1080
Texture Detail: ULTRA
Shadows Detail: ULTRA
Draw Distance: ULTRA
Anti-aliasing: HIGH
Supersampling: 4.0x
Anisotropic Level: 16
Obscurance Fields: ON
Tessellation: ON
Ambient Occlusion: ON
Motion Blur: ON
Vertical Sync: OFF
Reduce Mouse Lag: OFF
Stereo 3D: OFF
23 Dec 2013
North Wales
Single 280X @1110/1575
FX-8320 @4.5
14.9.2 Drivers
Mantle
1080p
Sniper Elite 3 Benchmark Report (Mantle)
Created: 2014-11-01 at 03:53:27
Average FPS: 44.1
Minimum FPS: 12.2
Maximum FPS: 87.2
Number Of Frames: 3367
Average Frame: 22.696ms
Minimum Frame: 11.467ms
Maximum Frame: 82.106ms
Monitors: 1
System RAM: 8107MB
Number of Cores: 8
Feature Level: Mantle
Anti-aliasing: HIGH
Supersampling: 4.0x
Tessellation: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
13 Jan 2004
UK
Here is my first one
i7 4970 4.0ghz @ 4.7
Corsair H80i cooler
EVGA 970 at stock
Created: 2014-11-01 at 07:06:36
Average FPS: 51.4
Minimum FPS: 16.7
Maximum FPS: 262.8
Number Of Frames: 3918
Average Frame: 19.473ms
Minimum Frame: 3.806ms
Maximum Frame: 59.839ms
Machine Name: ADMIN
Monitors: 1
Operating System: Windows 8 (build 9200), 64-bit
System RAM: 8135MB
CPU: Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz
Number of Cores: 8
GPU Name: NVIDIA GeForce GTX 970
Anti-aliasing: HIGH
Supersampling: 4.0x
Tessellation: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
Man of Honour
OP
21 May 2012
Dalek flagship
Corsair H80i cooler
EVGA 970 at stock
Average FPS: 51.4
Minimum FPS: 16.7
Maximum FPS: 262.8
Machine Name: ADMIN
Monitors: 1
System RAM: 8135MB
Number of Cores: 8
Anti-aliasing: HIGH
Supersampling: 4.0x
Tessellation: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
Could you post the drivers used and the actual clockspeed of the card please.:)
There are at least 4 different 970 versions that EVGA produce each with different stock clocks.:)
Thanks.
Caporegime
17 Mar 2012
ARC-L1, Stanton System
Powercolor PCS+ R9 290 @ 1200/1450
AMD FX-8350 @ 4.5Ghz
Cat: 14.9.2
1080P
Mantle: 62.5
Created: 2014-11-01 at 18:30:00
Average FPS: 62.5
Minimum FPS: 7.8
Maximum FPS: 339.0
Number Of Frames: 4783
Average Frame: 16.007ms
Minimum Frame: 2.950ms
Maximum Frame: 128.164ms
Machine Name: DESKTOP
Monitors: 1
System RAM: 8137MB
CPU: AMD FX(tm)-8350 Eight-Core Processor
Number of Cores: 8
Dedicated VRAM: 4096MB
Anti-aliasing: HIGH
Supersampling: 4.0x
Tessellation: ON
Motion Blur: ON
Vertical Sync: OFF
Reduce Mouse Lag: ON
Stereo 3D: OFF
DirectX 59.7
Created: 2014-11-01 at 18:32:54
Average FPS: 59.7
Minimum FPS: 16.9
Maximum FPS: 119.2
Number Of Frames: 4552
Average Frame: 16.752ms
Minimum Frame: 8.389ms
Maximum Frame: 59.004ms
Monitors: 1
System RAM: 8137MB
Number of Cores: 8
Anti-aliasing: HIGH
Supersampling: 4.0x
Tessellation: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
Caporegime
24 Sep 2008
Essex innit!
Created: 2014-11-03 at 16:14:52
Average FPS: 61.8
Minimum FPS: 16.7
Maximum FPS: 655.3
Number Of Frames: 4711
Average Frame: 16.188ms
Minimum Frame: 1.526ms
Maximum Frame: 59.887ms
Machine Name: GREGSTERS
Monitors: 1
System RAM: 16323MB
CPU: Intel(R) Core(TM) i7-3930K CPU @ 3.20GHz
Number of Cores: 12
GPU Name: NVIDIA GeForce GTX TITAN
Anti-aliasing: HIGH
Supersampling: 4.0x
Tessellation: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
3930K @ 3.8 - GTX Titan @ 1306/3758 - 344.48 - 1080P
Geeman kindly sent me a code 9Thanks Mateeee) :)
20 Nov 2005
Redditch
R9 295x2 1020/1300
4770K @ 4.5ghz
1440p
Created: 2014-11-03 at 22:01:16
Average FPS: 66.1
Minimum FPS: 12.7
Maximum FPS: 827.4
Number Of Frames: 5038
Average Frame: 15.136ms
Minimum Frame: 1.209ms
Maximum Frame: 78.481ms
Machine Name: *********
Monitors: 1
System RAM: 16327MB
CPU: Intel(R) Core(TM) i7-4770K CPU @ 3.50GHz
Number of Cores: 8
Resolution Width: 2560
Resolution Height: 1440
Anti-aliasing: HIGH
Supersampling: 4.0x
Tessellation: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
Man of Honour
OP
21 May 2012
Dalek flagship
R9 295x2 1020/1300
4770K @ 4.5ghz
1440p
Average FPS: 66.1
Minimum FPS: 12.7
Maximum FPS: 827.4
Monitors: 1
System RAM: 16327MB
Number of Cores: 8
Anti-aliasing: HIGH
Supersampling: 4.0x
Tessellation: ON
Motion Blur: ON
Vertical Sync: OFF
Stereo 3D: OFF
Could you post what drivers you are using please.:)
30 Nov 2011
As the guy says, the game is very samey, and for the title you would expect it to be a sniper type game, but you can actually breeze through most of the levels just playing as a run and gun fps
Bring back a proper tactical shooter like rainbow six
