Dirt Rally Benchmark
Status
Not open for further replies.
29 Aug 2010
Cornwall
1440p
1 GPU
  1. Score 91.67 GPU TitanX @1471/2002, CPU 5960x @4.6, Kaapstad Link 350.12 Drivers
    [*]Score 97.98 GPU 290X @1230/1625, CPU 5960x @4.6, Kaapstad Link 15.4 Drivers
  2. Score 39.24 GPU 285 @1200/1500, CPU 5960x @4.0, AMDMatt Link 15.4 Drivers
I think you listed the 1080p score instead of the 1440p score.
On a side note, based on the screenshots in the opening posts, this game does not look good does it?
With some of the Forza offerings and Project Cars you sometimes have to look twice to see if it was real or in-game. No such issue with this game it seems.
Caporegime
OP
12 Jul 2007
United Kingdom
Thanks, corrected.
Game looks very nice i think, the lightning effects are great. The problem is I'm rubbish at it, staying on the track is the biggest challenge I'm facing. It feels completely different to Dirt Showdown!
Please remember those screenshots are 720P. :)
27 Feb 2012
Two entirely different games, surely if you were interested in buying PCars, Assetto Corsa would be your racing game to get, not coincidently one that happens to be a Gaming Evolved title :rolleyes:
Caporegime
17 Mar 2012
ARC-L1, Stanton System
Assetto Corsa sucks, The Gran Turismo series are the best car racing games, well, the early ones are.
I remember GT1 back in the mid / late 90's, yes i'm old.
21 Jul 2012
Bolton
i5 3570k @ 4.5ghz
R9 290 TriX OC @ 1030/1400
15.4.1 drivers
1080p:
<?xml version="1.0" encoding="UTF-8" ?>
<!-- Benchmark Mode Results -->
<benchmark directx11_feature_level="11.0" instruction_set="SSE2" author="Richard" date="16:45:08 on 09/05/2015" machine="PC">
<totals races="1" total_time="00:03:08" total_race_time="00:03:08" race_time="00:03:08" />
<fps_race min_fps="66.654175" max_fps="109.574432" av_fps="82.541153" min_fps_ms="15.002811" max_fps_ms="9.126217" av_fps_ms="12.115169" />
<fps_total min_fps="66.654175" max_fps="109.574432" av_fps="82.541153" min_fps_ms="15.002811" max_fps_ms="9.126217" av_fps_ms="12.115169" />
<track index="1" numInRotation="1" totalProfiled="1">
<results samples="15536" min_fps="66.654175" max_fps="109.574432" av_fps="82.541153" min_fps_ms="15.002811" max_fps_ms="9.126217" av_fps_ms="12.115169" battery_percentage_used="0" />
<settings name="hafren_rally_01" route="route_2">
<car name="555" livery="17" />
</settings>
</track>
<hardware_settings_config version="8" deviceId="0x67B1">
<cpu>
<threadStrategy workerMapFile="system/workerMap4Core.xml" forceFeedbackProcessor="3" dvdStorageProcessor="3" dataSetMonitorProcessor="1" renderProcessor="0" updateProcessor="2" fileStreamProcessor="3" />
</cpu>
<audio_card>
<dynamic_range value="high" />
<eq value="headphones" />
</audio_card>
<graphics_card rating="1" firstBoot="true">
<directx forcedx10="false" />
<eyefinity force="" osd="" />
<stereo enabled="false" separation="0.015" convergence="0.5" />
<resolution width="1920" height="1080" aspect="16:9" fullscreen="true" vsync="0" multisampling="8xmsaa">
<refreshRate rate="59" />
</resolution>
<gamma level="0.8" />
</graphics_card>
<shadows enabled="true" size="3072" maskQuality="2" particles="true" />
<advanced_fog enabled="true" />
<particles enabled="true" wind="true" dynamicRes="false" lowResScalar="2" nearFadeBias="0" />
<weather quality="1" />
<crowd enabled="true" detail="4" />
<cloth enabled="true" tessellation="true" />
<groundcover mode="ultra" clutter="true" />
<objects lod="1.02" maxlod="0" stones="true" />
<trees lod="1.2" maxlod="0" meshes="true" meshes_in_all_passes="false" />
<vehicles characterQuality="4" lodQuality="3" />
<track lod="1.0" />
<envmap faces="6" size="1024" drawallobjects="true" scaleminsize="0.75" mindistance="150.0" />
<water update="true" detail="3" scale="2" drawallobjects="true" tessellation="true" />
<mirrors enabled="true" width="768" height="256" car_maxlod="2" car_culldist="300.0" />
<skidmarks enabled="true" />
<dynamic_ambient_occ enabled="true" quality="4" />
<dynamic_ambient_occ_soft enabled="true" />
<night_lighting volumes="true" lights="0" shadows="true" onlyHeadlights="false" shadowSize="2048" />
<textures resolution="3" />
<shaders quality="2" low_quality="false" />
<anisotropic min="4" max="16" />
<physics environmentalDamage="true" vehicleDamage="true" />
<input device_type="auto" />
<motion enabled="true" ip="dbox" port="20777" delay="1" extradata="0" />
<screenshotMode enabled="false" />
<aoit enabled="false" />
<avsm enabled="true" />
<oculus enabled="true" headMovement="true" chromatic="true" timeWarp="true" vignette="true" overdrive="true" convergence="1.0" verticalOrientation="0.66" />
</hardware_settings_config>
</benchmark>
29 Jun 2014
Herts
[email protected]
970's@1506/2003
350.12
1080p
1card:
<benchmark directx11_feature_level="11.0" instruction_set="SSE2" author="George" date="18:43:07 on 09/05/2015" machine="George-PC">
<fps_race min_fps="69.565277" max_fps="101.193428" av_fps="81.480461" min_fps_ms="14.374988" max_fps_ms="9.882065" av_fps_ms="12.272881" />
<fps_total min_fps="69.565277" max_fps="101.193428" av_fps="81.480461" min_fps_ms="14.374988" max_fps_ms="9.882065" av_fps_ms="12.272881" />
<results samples="15336" min_fps="69.565277" max_fps="101.193428" av_fps="81.480461" min_fps_ms="14.374988" max_fps_ms="9.882065" av_fps_ms="12.272881" battery_percentage_used="0" />
</settings>
</track>
<hardware_settings_config version="8" deviceId="0x13C2">
<cpu>
<threadStrategy workerMapFile="system/workerMap8Core.xml" forceFeedbackProcessor="6" dvdStorageProcessor="7" dataSetMonitorProcessor="4" renderProcessor="0" updateProcessor="2" fileStreamProcessor="5" />
</cpu>
<audio_card>
<eq value="flat" />
</audio_card>
<graphics_card rating="4" firstBoot="true">
<resolution width="1920" height="1080" aspect="auto" fullscreen="true" vsync="0" multisampling="8xmsaa">
<refreshRate rate="60" />
</resolution>
</graphics_card>
<track lod="1.0" />
</benchmark>
2cards:
<benchmark directx11_feature_level="11.0" instruction_set="SSE2" author="George" date="18:35:40 on 09/05/2015" machine="George-PC">
<fps_race min_fps="90.583664" max_fps="132.068176" av_fps="112.204330" min_fps_ms="11.039518" max_fps_ms="7.571847" av_fps_ms="8.912312" />
<fps_total min_fps="90.583664" max_fps="132.068176" av_fps="112.204330" min_fps_ms="11.039518" max_fps_ms="7.571847" av_fps_ms="8.912312" />
<results samples="21119" min_fps="90.583664" max_fps="132.068176" av_fps="112.204330" min_fps_ms="11.039518" max_fps_ms="7.571847" av_fps_ms="8.912312" battery_percentage_used="0" />
</settings>
</track>
<cpu>
</cpu>
<audio_card>
<eq value="flat" />
</audio_card>
</resolution>
</graphics_card>
<track lod="1.0" />
</benchmark>
Caporegime
OP
12 Jul 2007
United Kingdom
[email protected]
970's@1506/2003
350.12
1080p
1card:
</settings>
</track>
<cpu>
</cpu>
<audio_card>
<eq value="flat" />
</audio_card>
</resolution>
</graphics_card>
<track lod="1.0" />
</benchmark>
2cards:
</settings>
</track>
<cpu>
</cpu>
<audio_card>
<eq value="flat" />
</audio_card>
</resolution>
</graphics_card>
<track lod="1.0" />
</benchmark>
Scoreboard updated. :)
You might actually like this game Pete, it's nothing at all like Dirt Showdown. :p
Caporegime
11 Jul 2009
BenefitStreetBirmingham
<?xml version="1.0" encoding="UTF-8"?>
-<benchmark machine="W8-PC" date="18:52:43 on 09/05/2015" author="p" instruction_set="SSE2" directx11_feature_level="11.0">
<totals race_time="00:03:08" total_race_time="00:03:08" total_time="00:03:08" races="1"/>
<fps_race av_fps_ms="17.210281" max_fps_ms="12.848535" min_fps_ms="21.937700" av_fps="58.104801" max_fps="77.829887" min_fps="45.583630"/>
<fps_total av_fps_ms="17.210281" max_fps_ms="12.848535" min_fps_ms="21.937700" av_fps="58.104801" max_fps="77.829887" min_fps="45.583630"/>
-<track totalProfiled="1" numInRotation="1" index="1">
<results av_fps_ms="17.210281" max_fps_ms="12.848535" min_fps_ms="21.937700" av_fps="58.104801" max_fps="77.829887" min_fps="45.583630" battery_percentage_used="0" samples="10937"/>
-<settings route="route_2" name="hafren_rally_01">
<car name="555" livery="17"/>
</settings>
</track>
-<hardware_settings_config deviceId="0x6798" version="8">
-<cpu>
<threadStrategy fileStreamProcessor="5" updateProcessor="2" renderProcessor="0" dataSetMonitorProcessor="4" dvdStorageProcessor="7" forceFeedbackProcessor="6" workerMapFile="system/workerMap8Core.xml"/>
</cpu>
-<audio_card>
<dynamic_range value="high"/>
<eq value="flat"/>
</audio_card>
-<graphics_card firstBoot="true" rating="1">
<directx forcedx10="false"/>
<eyefinity osd="" force=""/>
<stereo convergence="0.5" separation="0.015" enabled="false"/>
-<resolution multisampling="8xmsaa" vsync="0" fullscreen="true" aspect="auto" height="1080" width="1920">
<refreshRate rate="59"/>
</resolution>
<gamma level="0.8"/>
</graphics_card>
<shadows enabled="true" particles="true" maskQuality="2" size="3072"/>
<advanced_fog enabled="true"/>
<particles enabled="true" nearFadeBias="0" lowResScalar="2" dynamicRes="false" wind="true"/>
<weather quality="1"/>
<crowd enabled="true" detail="4"/>
<cloth enabled="true" tessellation="true"/>
<groundcover clutter="true" mode="ultra"/>
<objects stones="true" maxlod="0" lod="1.02"/>
<trees maxlod="0" lod="1.2" meshes_in_all_passes="false" meshes="true"/>
<vehicles lodQuality="3" characterQuality="4"/>
<track lod="1.0"/>
<envmap size="1024" mindistance="150.0" scaleminsize="0.75" drawallobjects="true" faces="6"/>
<water detail="3" tessellation="true" drawallobjects="true" scale="2" update="true"/>
<mirrors enabled="true" height="256" width="768" car_culldist="300.0" car_maxlod="2"/>
<skidmarks enabled="true"/>
<dynamic_ambient_occ enabled="true" quality="4"/>
<dynamic_ambient_occ_soft enabled="true"/>
<night_lighting shadowSize="2048" onlyHeadlights="false" shadows="true" lights="0" volumes="true"/>
<textures resolution="3"/>
<shaders quality="2" low_quality="false"/>
<anisotropic max="16" min="4"/>
<physics vehicleDamage="true" environmentalDamage="true"/>
<input device_type="auto"/>
<motion enabled="true" extradata="0" delay="1" port="20777" ip="dbox"/>
<screenshotMode enabled="false"/>
<aoit enabled="false"/>
<avsm enabled="true"/>
<oculus convergence="1.0" enabled="true" verticalOrientation="0.66" overdrive="true" vignette="true" timeWarp="true" chromatic="true" headMovement="true"/>
</benchmark>
58.1 fps avg
3770k @4.6ghz
7970 @1150/1660 MHz
14.11.2 drivers
Caporegime
OP
12 Jul 2007
United Kingdom
Fair enough ^^^ :)
Am i the only one who liked Dirt Showdown?
I enjoyed it, it was fun MP
Dirt Showdown was good, easy fun. Not a serious racer at all, but that was its charm.
</settings>
</track>
-<cpu>
</cpu>
-<audio_card>
<eq value="flat"/>
</audio_card>
</resolution>
</graphics_card>
<track lod="1.0"/>
</benchmark>
58.1 fps avg
3770k @4.6ghz
7970 @1150/1660 MHz
14.11.2 drivers
And on the scoreboard. :)
Caporegime
17 Mar 2012
Yeah, i'm not a serious racer, a bunch of lunatics smashing eachother about in cars is what DS was about and i loved it, huge fun, side-splitting from start to end, you couldn't even see the screen half the time, it was all just a blur through tears of laughter.
18 Mar 2012
Eastbourne
4690k @ 4.7
290x @ 1175/1625
15.4
DX11
1080p
<benchmark directx11_feature_level="11.0" instruction_set="SSE2" author="Sam&apos;s Gaming" date="20:14:48 on 09/05/2015" machine="SamsGaming-PC">
<fps_race min_fps="67.440971" max_fps="106.494873" av_fps="83.020073" min_fps_ms="14.827782" max_fps_ms="9.390123" av_fps_ms="12.045280" />
<fps_total min_fps="67.440971" max_fps="106.494873" av_fps="83.020073" min_fps_ms="14.827782" max_fps_ms="9.390123" av_fps_ms="12.045280" />
<results samples="15626" min_fps="67.440971" max_fps="106.494873" av_fps="83.020073" min_fps_ms="14.827782" max_fps_ms="9.390123" av_fps_ms="12.045280" battery_percentage_used="0" />
</settings>
</track>
<hardware_settings_config version="8" deviceId="0x67B0">
<cpu>
</cpu>
<audio_card>
<eq value="flat" />
<music level="0.00" />
</audio_card>
<refreshRate rate="144" />
</resolution>
</graphics_card>
<track lod="1.0" />
</benchmark>
I'm absolutely loving this game at the moment!! :D
20 Feb 2007
‎ツ
Intel i7 3820 @ 4.3GHz
Single GTX 980 @ 1405/7404
350.12 drivers.
1080P
<benchmark directx11_feature_level="11.0" instruction_set="SSE2" author="Jase" date="23:03:31 on 09/05/2015" machine="Jase-PC">
<fps_race min_fps="73.276207" max_fps="104.831566" av_fps="84.870438" min_fps_ms="13.646995" max_fps_ms="9.539111" av_fps_ms="11.782666" />
<fps_total min_fps="73.276207" max_fps="104.831566" av_fps="84.870438" min_fps_ms="13.646995" max_fps_ms="9.539111" av_fps_ms="11.782666" />
<results samples="15974" min_fps="73.276207" max_fps="104.831566" av_fps="84.870438" min_fps_ms="13.646995" max_fps_ms="9.539111" av_fps_ms="11.782666" battery_percentage_used="0" />
</settings>
</track>
<hardware_settings_config version="8" deviceId="0x13C0">
<cpu>
</cpu>
<audio_card>
<eq value="flat" />
</audio_card>
</resolution>
</graphics_card>
<track lod="1.0" />
</benchmark>
2015-05-09_00005_zpspnmqazje.jpg~original
1440P
<benchmark directx11_feature_level="11.0" instruction_set="SSE2" author="Jase" date="23:07:39 on 09/05/2015" machine="Jase-PC">
<fps_race min_fps="51.117783" max_fps="71.901047" av_fps="59.241741" min_fps_ms="19.562664" max_fps_ms="13.908004" av_fps_ms="16.879990" />
<fps_total min_fps="51.117783" max_fps="71.901047" av_fps="59.241741" min_fps_ms="19.562664" max_fps_ms="13.908004" av_fps_ms="16.879990" />
<results samples="11150" min_fps="51.117783" max_fps="71.901047" av_fps="59.241741" min_fps_ms="19.562664" max_fps_ms="13.908004" av_fps_ms="16.879990" battery_percentage_used="0" />
</settings>
</track>
<cpu>
</cpu>
<audio_card>
<eq value="flat" />
</audio_card>
<resolution width="2560" height="1440" aspect="auto" fullscreen="true" vsync="0" multisampling="8xmsaa">
</resolution>
</graphics_card>
<track lod="1.0" />
</benchmark>
2015-05-09_00006_zpsn250dj09.jpg~original
Great game, at last Codemasters have listened to what people want, less Ken Block gymkhana crap, more hardcore rallying!
Status
