Caporegime
But surely the 15.20 which have the fury in the inf and are dated 3 days newer are also specifically designed too?
Greebo, i cannot comment on any drivers which we've not officially released through our usual channels.
So 4GB Vram and an overclock......... Nor does your link comment on gcn variation.
http://www.guru3d.com/articles-pages/msi-radeon-r9-390x-gaming-8g-oc-review,1.html
'When the AMD Radeon R9 290X was released, it finally had architectural improvements over the 7970 that increased the GCN version a bit. However, that was back in 2013 that the AMD Radeon R9 290X codenamed (Hawaii) was released. So here we are two years later, and basically we are getting a re-brand of Hawaii with the R9 390 and 390X. This time, no architectural improvements.
What does that mean as far as performance and specs go? Well if you look above at the specifications for the AMD Radeon R9 390X above (the one we are reviewing today) you will note it shares all the same specifications with the AMD Radeon R9 290X. Both the AMD Radeon R9 290X and AMD Radeon R9 390X are built at 28nm, have 2816 Streaming Processors, 176 texture units, 64 ROPs and 44 Compute Units. Both utilize 512-bit memory busses with GDDR5.
There are only three things that separates the R9 390X from the R9 290X. The first thing is a higher default stock GPU clock speed of 1050MHz versus 1000MHz on the R9 290X. The second is that the memory is clocked a lot higher this time around at 6GHz versus 5GHz on the AMD Radeon R9 290X. This brings the memory bandwidth up to 384GB/sec versus 320GB/sec. Finally, the R9 390X will come standard with 8GB of VRAM versus 4GB on the R9 290X.'
So 4GB Vram and an overclock..........
Im using the 15.20 drivers and no card not flashed, the inf is just modded.
Just run 3dmark firestrike. Total score went from 14109 to 14599 but more importantly the gfx score went from 21735 to 22792, a 9.1% increase!
I suspect a lot of the positive gains from the 3 series cards in reviews over their equivalent 2 series is purely down to the new drivers.
There is even better to come with the 15.30 drivers so AMD claim!
If i can get a 9% increase in games as well then all is good. I am beating some titan tx which are overclocked now in the ocuk 3dmark database!
I know the paper specs are the same, how about reading what I linked to? The overclock and extra ram arnt the reason for improved tessellation performance. Nor does your link comment on gcn variation.
Massive boost using this driver with 290 cards though as well, up to 10% in 3dmark and people are reporting 10 fps (20% gain) in witcher with them too
And what about the clock for clock test they did when they lowered the 390X to the same clock as the 290X, they had identical scores in all the games tested. As I said just extra vram with an overclock.
It doesnt seem to be GCN 1.1
http://www.hardocp.com/article/2015/06/18/msi_r9_390x_gaming_8g_video_card_review/3#.VYMmMlVVhBf
Hardocp reporting the large tessellation performance of the GCN 1.2. I suspect Drivers are the cause of its middling performance so far. Not enough to swap from a 290x but it seems like more of a refresh than a straight rebrand to me.
There is the NL sire which used 15.15 drivers for both 290x and 390x and the 390x beats the 290x by 1 or 2 fps in each test and thats all.
And thats probably due to the slightly higher clocks.
But at least it shows great performance for both 290x and 390x.
Just wish AMD could have given 290x owners these drivers months ago
Where can you get the 15.15? I had 14. Drivers and could only find the 15.5 version on the AMD website?
You cannot simply flash the 390x bios into a 290x card unless you want instability etc.
Yeah you can, somebody on another forum even edited the 390X BIOS to 4GB just for that purpose.
lol @ AMD... absolute idiots... for the last few years they have only won market share from NVidia because they have been price/performance competative.
15.15 here http://forum.guru3d.com/showthread.php?t=400078
but the 15.20 are newer and faster http://forum.guru3d.com/showthread.php?t=399956
Both are for the 390 and fury cards but with modded inf they work fine on 290/290x cards
Which are newer 15.20 or. 15.200.1040 for win 10?
