The GTX 980 Ti owners thread.
3 Mar 2009
Hey guys, here's my MSI 980Ti 6g. Really impressed with the noise levels and the coil whine is very minimal too compared to my MSI 280x which was quite bad for it. If anyone is thinking of getting the MSI card and has any questions just ask.
19 Oct 2002
Also from ocn.
"It is the way to set your max stable oc to the last clock of the boost table, and then setting all values in the voltage table that are LARGER than your max allotted (or available) voltage to your max allotted (or available) voltage. In other words: You would then adjust the voltage table because if you do NOT, the entire voltage table is not being used. Here just an example: Some cards are voltage limited and can only supply a max of 1.212V (which is plenty, by the way). HOWEVER, example, say, in your voltage table, CLK73 has 1275.0V -1281.3V. It would never jump to this entry since this voltage is already far out of range of your available voltage! By adjusting those values which are HIGHER than your max voltage you make it so that your entire voltage table is actually available."
This also cinfirms my thoughts that the card could never boost to 74.
Are you using ref card varkanoid or amp? I suspect ref as amp bios should bevidentical to mine which would suggest amp is more limited than ref for some reason.
Look at you voltage minimum for entry 74 on your bios. I suspect it is below or at 1250mv mine is at 1281mv which is a voltage i cant provide to the card without a bios edit. I suspect they closed off those entries for a reason but why.....
7 Jun 2013
Hello mate! Fellow Inno3D ultra owner here :) Love this card, but no rattle to speak of. How is this manifesting itself exactly if you haven't tried it yet?
I've been using it since Thursday just no forum access till tonight. Was fine till the early hours was boosting the fans a bit and its started to rattle. I'm going to take it back out me rig and hope something is loose. I was running on max fans for about 15mins when it started. I love the card also so would rather not send it back
8 Dec 2004
Hampshire
Definitely take it out the rig and investigate!
31 Dec 2007
The TARDIS, Wakefield, UK
Also from ocn.
ref card. My 74 is 1281mv.
I see what you mean about voltage locked now. Everytime I look at the Bios Tweaker it usually gives me a headache figuring it out again.
However its not really limiting my overclock to what I like to achieve. At the moment its doing 1429mhz with 1.19v which I think is pretty good.
Altering the slider in Afterburner only lets me add +87mv which shows as 1.23v max so its possibly Afterburner first limiting me.
9 Mar 2008
Mine seems to of started to have some issues. Was absolutely flawless Friday and Saturday but today I have noticed a lot of problems particularly in BF4 and GTAV.
In GTA the frames keep dropping to single figures where as before I was getting rock solid 60 with vsync. Went onto BF4 earlier and I was struggling to maintain 70fps on 48+ player servers. Although I did have a go at BF4 CTE on friday and was easily well over 100fps on dragon valley.
The only thing I did change was the dynamic super resolution option to give that a go. Since turned it off but the problems persist. Any ideas?
1 Nov 2010
Finally got mine in, had it since 16/06/2015 but been too busy with work until this weekend.
7 Jun 2013
You've not really been keeping up with the Acer threads in the monitor section have you ?
Make sure you return it under the 14 day rule and get a refund not RMA for replace/repair!
Just been reading them over the weekend. Really like the monitor when it works but yeah took the chance of the b grade special and looks like it's not going to work out for me. Just wondering what to get to replace it g-sync is looking great to help with lower framerates.
8 Nov 2006
Wish had more time to use my cards. Hating my job lately. Just sucking up so much of spare time - even so far as been sick over weekend, but still been working today :(
Still, managed a bit of time on arkham knight, and even though it could be better optimised, still enjoyable, and not experiencing a lot of crashes.
7 Jun 2013
Hey Varkanoid how is the Samsung U28D590 you have compared I was looking at one of them but thought the acer with g-sync was a good idea when I bought it from looking at the recent reviews on the shop page. Looks like I was so wrong.
11 May 2009
Question for Spok or any other MSI non ref owners - bit of an odd one, but how easy do you think it would be to hide/paint the red parts of the cooler? I like MSI cards but being a bit picky as I would prefer a gold/yellow and black design to go with the rest of my case.
2 Apr 2011
Looks pretty hard to me.
Man of Honour
OP
21 May 2012
Dalek flagship
Welcome and TROH updated.:)
The Roll of Honour.
Make EVGA Hybrid, SaintJimmy, Link, Date 28/06/2015
Make MSI Gaming, Spokwiththeears, Link, Date 28/06/2015
Make Reference, goochinbuda, Link, Date 28/06/2015
Make Inno3D X3, Newu_boy, Link, Date 28/06/2015
Make MSI Gaming, Wyrdo, Link, Date 28/06/2015
Make Gigabyte G1, Radeon123, Link, Date 27/06/2015
Make MSI Gaming, gt11, Link, Date 27/06/2015
Make Zotac AMP Edition, DBT85, Link, Date 27/06/2015
Make Gigabyte G1, Rivod, Link, Date 27/06/2015
Make MSI Gaming, Milky1, Link, Date 27/06/2015
Make EVGA SC ACX, fornowagain, Link, Date 27/06/2015
Make Zotac AMP Edition, Angerer, Link, Date 27/06/2015
Make EVGA Hybrid, alexp999, Link, Date 27/06/2015
Make MSI Gaming, ubersonic, Link, Date 27/06/2015
Make MSI Gaming, lnoton, Link, Date 27/06/2015
Make Zotac AMP Edition, Type_R, Link, Date 27/06/2015
Make Reference, Wrxengland, Link, Date 27/06/2015
Make Zotac AMP Edition, agt, Link, Date 27/06/2015
Make EVGA SC ACX, Scramz, Link, Date 26/06/2015
Make Inno3D X3, Cavallino, Link, Date 26/06/2015
Make MSI Gaming, LauraLC, Link, Date 26/06/2015
Make Reference, Winnter, Link, Date 26/06/2015
Make Reference, Clov!s, Link, Date 26/06/2015
Make Inno3D X3, razorpakk, Link, Date 26/06/2015
Make MSI Gaming, titaniumx3, Link, Date 26/06/2015
Make Zotac AMP Edition, PowerPie5000, Link, Date 26/06/2015
Make EVGA SC ACX, thefogo, Link, Date 26/06/2015
Make Zotac AMP Edition, mufc802, Link, Date 26/06/2015
Make EVGA SC ACX, GeneralD, Link, Date 26/06/2015
Make Zotac AMP Edition, Rossi~, Link, Date 26/06/2015
Make MSI Gaming, tyler_jrb, Link, Date 26/06/2015
Make Zotac AMP Edition, picnic, Link, Date 26/06/2015
Make MSI Gaming, DeanT77, Link, Date 26/06/2015
Make MSI Gaming, Brutos, Link, Date 26/06/2015
Make Zotac AMP Edition, Buck890, Link, Date 26/06/2015
Make MSI Gaming, se_vietboi, Link, Date 26/06/2015
Make Reference, Cottee, Link, Date 26/06/2015
Make EVGA SC ACX, ZeroG, Link, Date 26/06/2015
Make EVGA SC ACX, clone, Link, Date 25/06/2015
Make MSI Gaming, GiB, Link, Date 25/06/2015
Make Inno3D X3, rootz, Link, Date 25/06/2015
Make Inno3D X3, Khorvos, Link, Date 25/06/2015
Make Reference, amigafan2003, Link, Date 25/06/2015
Make Inno3D X3, theor14, Link, Date 25/06/2015
Make Inno3D X3, rickyjb, Link, Date 25/06/2015
Make Reference, floatindolphin, Link, Date 24/06/2015
Make Reference, eviljester91, Link, Date 23/06/2015
Make Reference, KillBoY_UK, Link, Date 23/06/2015
Make Gigabyte G1, Kered_Dub, Link, Date 23/06/2015
Make Gigabyte G1, Wrinkly, Link, Date 22/06/2015
Make Gigabyte G1, ronnie136, Link, Date 22/06/2015
Make Gigabyte G1, WHAT21A, Link, Date 22/06/2015
Make EVGA SC Ref, Divine Pain, Link, Date 22/06/2015
Make Gigabyte G1, AhadielGames, Link, Date 22/06/2015
Make Gigabyte G1, Shivji, Link, Date 20/06/2015
Make Reference, M1keMK, Link, Date 18/06/2015
Make EVGA SC ACX, ihatelag, Link, Date 18/06/2015
Make Reference, Diuz, Link, Date 18/06/2015
Make Reference, C3PO, Link, Date 18/06/2015
Make Reference, psychas, Link, Date 18/06/2015
Make Reference, MasterOC, Link, Date 18/06/2015
Make EVGA SC ACX, Malesu, Link, Date 17/06/2015
Make EVGA SC ACX, Mayh3M, Link, Date 17/06/2015
Make EVGA SC ACX, IT Troll, Link, Date 17/06/2015
Make EVGA SC Ref, jetpaczx, Link, Date 17/06/2015
Make Gigabyte G1 Gaming, Brutus, Link, Date 17/06/2015
Make Gigabyte G1 Gaming, youdsy, Link, Date 17/06/2015
Make Gigabyte G1 Gaming, HidYn, Link, Date 17/06/2015
Make Gigabyte G1 Gaming, Matthew89, Link, Date 17/06/2015
Make Gigabyte G1 Gaming, delpy8, Link, Date 17/06/2015
Make EVGA SC ACX, Axekickjack, Link, Date 17/06/2015
Make EVGA SC ACX, ArnieRambo, Link, Date 16/06/2015
Make EVGA SC ACX, agnes, Link, Date 16/06/2015
Make EVGA Hydro Copper, Giggz, Link, Date 16/06/2015
Make EVGA Hybrid, Muska, Link, Date 16/06/2015
Make EVGA Hybrid, is149, Link, Date 16/06/2015
Make Reference, The Mad One, Link, Date 15/06/2015
Make EVGA SC ACX, Valenni, Link, Date 15/06/2015
Make EVGA SC ACX, OldBoy75, Link, Date 15/06/2015
Make EVGA Hybrid, shiver, Link, Date 14/06/2015
Make Reference, ICEx21, Link, Date 14/06/2015
Make Reference, varkanoid, Link, Date 13/06/2015
Make EVGA SC ACX, JunglistE, Link, Date 13/06/2015
Make Reference, Gripen90, Link, Date 12/06/2015
Make Reference, Strife212, Link, Date 11/06/2015
Make Reference, saintdefender, Link, Date 11/06/2015
Make Reference, crazy8s, Link, Date 10/06/2015
Make Reference, Tom Martow, Link, Date 10/06/2015
Make Reference, rpggamesplayer, Link, Date 10/06/2015
Make Reference, toon_mad, Link, Date 10/06/2015
Make Reference, jjgreenwood, Link, Date 10/06/2015
Make Reference, Razor Time, Link, Date 10/06/2015
Make Reference, SeeNoWeevil, Link, Date 10/06/2015
Make Reference, RyanF, Link, Date 09/06/2015
Make Reference, roozor, Link, Date 09/06/2015
Make EVGA SC ACX, perosus, Link, Date 09/06/2015
Make Reference, ZombieDescartes, Link, Date 09/06/2015
Make Reference, Techen, Link, Date 08/06/2015
Make Reference, Rap1D, Link, Date 06/06/2015
Make Reference, khemist, Link, Date 06/06/2015
Make EVGA SC Ref, ciggybumly, Link, Date 05/06/2015
Make EVGA SC Ref, N19h7m4r3, Link, Date 04/06/2015
Make Reference, queeg, Link, Date 04/06/2015
Make Reference, abaddon, Link, Date 03/06/2015
Make Reference, Volv, Link, Date 03/06/2015
Make Reference, Larcwide, Link, Date 02/06/2015
Make Reference, a66as, Link, Date 02/06/2015
Make Reference, Angst, Link, Date 02/06/2015
Make Reference, RichardH754, Link, Date 02/06/2015
Make Reference, Phixsator, Link, Date 01/06/2015
Make Reference, Tommy_Here, Link, Date 01/06/2015
To get on the Roll of Honour all you have to do is post a pic with your user name on it of your 980 Ti.​
