Not sure why it says lacp enabled.
ifIndex 19
Port Type Normal
Port Channel ID Disable
Port Role Designated
STP Mode Enable
STP State Forwarding
Admin Mode Enable
Flow Control Mode Disable
LACP Mode Enable
Physical Mode Auto
Physical Status 1000 Mbps
Link Status Link Up
Link Trap Enable
Packets RX and TX 64 Octets 437178841
Packets RX and TX 65-127 Octets 47022406
Packets RX and TX 128-255 Octets 9528284
Packets RX and TX 256-511 Octets 4549171
Packets RX and TX 512-1023 Octets 3904132
Packets RX and TX 1024-1518 Octets 1732503071
Packets RX and TX 1519-2047 Octets 0
Packets RX and TX 2048-4095 Octets 0
Packets RX and TX 4096-9216 Octets 0
Octets Received 1189081540207
Packets Received 64 Octets 422535301
Packets Received 65-127 Octets 45472749
Packets Received 128-255 Octets 6138362
Packets Received 256-511 Octets 3393775
Packets Received 512-1023 Octets 2818597
Packets Received 1024-1518 Octets 760823578
Packets Received > 1518 Octets 0
Total Packets Received Without Errors 1241182362
Unicast Packets Received 1241141636
Multicast Packets Received 26249
Broadcast Packets Received 14477
Receive Packets Discarded 0
Total Packets Received with MAC Errors 0
Jabbers Received 0
Fragments Received 0
Undersize Received 0
Alignment Errors 0
Rx FCS Errors 0
Overruns 0
Total Received Packets Not Forwarded 0
802.3x Pause Frames Received 0
Unacceptable Frame Type 0
Total Packets Transmitted (Octets) 1476878822537
Packets Transmitted 64 Octets 14643540
Packets Transmitted 65-127 Octets 1549657
Packets Transmitted 128-255 Octets 3389922
Packets Transmitted 256-511 Octets 1155396
Packets Transmitted 512-1023 Octets 1085535
Packets Transmitted 1024-1518 Octets 971679493
Packets Transmitted > 1518 Octets 0
Maximum Frame Size 1518
Total Packets Transmitted Successfully 993503543
Unicast Packets Transmitted 989396318
Multicast Packets Transmitted 1400441
Broadcast Packets Transmitted 2706784
Transmit Packets Discarded 18832
Total Transmit Errors 0
Total Transmit Packets Discarded 0
Single Collision Frames 0
Multiple Collision Frames 0
Excessive Collision Frames 0
Dropped Transmit Frames 18832
STP BPDUs Received 0
STP BPDUs Transmitted 0
RSTP BPDUs Received 0
RSTP BPDUs Transmitted 44388
MSTP BPDUs Received 0
MSTP BPDUs Transmitted 0
802.3x Pause Frames Transmitted 0
EAPOL Frames Received 0
EAPOL Frames Transmitted 0
Time Since Counters Last Cleared 8 day 0 hr 27 min 52 sec
