Alienware 15 R3 (2016) unboxing (56k no!)
OP
18 Oct 2002
Hemel
I managed to sneak an order in before the prices went up so I picked up the 15 R3 with i7-6700HQ, 16GB DDR4, GTX 1070 and 1080p 120hz G-Sync display for £1880 inc VAT.
I opted to keep just the base HDD option so it's got 1TB SATA, but has room for M.2 SSD's inside. I felt it'll be cheaper to put my own drives in than bump the price of the laptop to over 2k.
20 Oct 2002
Redcar
Thanks for this, loving the classic thread title :D
Please can I request a good picture of the power adaptor / brick please
Can you put it on a piece of A4 paper or something similar for scale? Dell are useless at supplying information on this as is almost all reviews online and YouTube!
6 Oct 2004
England
Nice! I paid roughly that for the same specs but 60hz instead of 120 :rolleyes:
Get some benching done :)
You can download 3Dmark free on steam and let us know the results.
28 Jul 2003
Dell is currently offering 12% off for Black Friday and Quidco is doing 7.7% on any dell purchase. Not sure if these can be used together or if Dell will decline the cashback but if they don't decline you can get:
* 17 R4 with a 1070, 256GB PCI-e / 7200 HDD, 16 GB 2667mhz Ram and QHD G-Sync for £1,867 inc
* 17 R4 with 1070, 7200 HDD, 8GB 2400mhz RAM and QHD G-sync for £1,623 inc
So you're effectively looking at a differential of £243 for an upgrade which includes 256GB PCI-e SSD and 8GB more ram.
Priced separately you could pick up a Samsung 960 256GB and Samsung 16GB Ram for about £200 so potentially save £43. Not great but you know, every little help
OP
18 Oct 2002
Hemel
Here you go :) That's a standard sheet of A4.
It's big, but not the biggest I've seen.
OP
18 Oct 2002
Hemel
This is exactly why I decided to stick with the 1TB mechanical drive and save a bit of money. It's far cheaper to put your own drives in, and thankfully the way the Alienware is designed maintenance is trivial.
£1800 on a laptop with upgrades possible in the future is a lot more acceptable for the other half than £2000+.
OP
18 Oct 2002
Hemel
First benchmark. I'm a bit out of touch in benchmarking these days so I have no idea if that's good or not or if 3DMark is even a good tool to use anymore.
Kind of crazy seeing those GPU tests never dropping below 30fps on a laptop!
5 Nov 2015
London
Goddamit was just about to buy an MSI GTX73 and they do the 12% offer got some thinking to do before the 28th, I'm liking the 1080 with the new g-sync screen
28 Jul 2003
HP are doing 15% off anything (SAVE15) including their laptops. It makes the Omen gtx 1070 with same specs as AW about £500 cheaper. Granted it's supposed to be a little noisy and gets a little hot but still £500 cheaper is a lot of dosh
