Can a PC build go into a Xbox?
5 Mar 2010
Why would that be cool?
You could stick PC components in literally anything. If you want something cool then let your imagination run wild rather than what's essentially swapping one computers components with another.
11 Oct 2009
Greater London
There was the NZXT H1 that was similar to the Xbox, although due to a bad riser cable that caught of fire no one really used it. There's also the SSPUD Meshilicious, but it's still a little more bigger than the Xbox.
29 May 2005
Wont play many games tho.
The exclusive range might be
Tetris
Mine sweep
Solitaire
Pong
Snake for Windows
OP
19 Oct 2002
I'm sure there are better looking "objects" than xbox case ;)
I very much like the Velka 7, it would be perfect if it was a little deeper, it is odd the way the GPU goes in that.
