Cleaned and Rain X'd the car + pumped out a little oil.
Shutters in - probably should have gone bright white vs. this slightly off white.
Haha yeah but what a look that would beThink that's the right choice tbh.
Bright white + sunlight might mean shades are required for sitting in the bath, facing the window.
Galvanised hinges? Bathroom moisture/steam is going to make them possibly rust and that can colour the condensation.. on white shutters..Shutters in - probably should have gone bright white vs. this slightly off white.
They're fully waterproof/bathroom approved. In fact my in-laws have their bath against the window and shutters get blasted by water.Galvanised hinges? Bathroom moisture/steam is going to make them possibly rust and that can colour the condensation.. on white shutters..
We were advised not to have shutters in the bathroom (we have them all around but the bathroom).
Also don't sit on the loo with the window open on a windy day ... face full of shutter
All about the clean bunsLooking closely at the image I suddenly realised you have a toilet built into the bath.
Is this some new type of bum washer
Face full of shutter whilst on the *****er!Galvanised hinges? Bathroom moisture/steam is going to make them possibly rust and that can colour the condensation.. on white shutters..
This man clearly doesn't Joseph Joseph (trademark)Not seen one of those drying racks before @dlockers . Looks like a medieval torture device.
Take a photo....because it's gradual you lose that instant satisfactionCut the grass and sprayed the patio, path and driveway with Wet&Forget... See if it lives upto the name.
Next time it's dark outside get your better half to go into bathroom -put light on then sit on the loo - You can be standing outside away from window and check for a shadow of your controlling officer.Shutters in - probably should have gone bright white vs. this slightly off white.
