My FTTC (with Enta) was installed on Monday
The first thing anyone does is find out how fast their connection is, so I've run a few tests. All are from the same PC (an HP Elitebook 8440p with a Core i7 etc etc on a CAT5 cable).
BT Speedtester reports the IP Profile as 34.1Mbps down / 10Mbps up As the crow-flies, I'm about 300m from the FTTC cabinet, probably 500m following the road. Expected speed was 16.6Mbps / 7.9Mbps, so the checker is as conservative as ever.
Direct into the VDSL modem:
Through a brand-new Zyxel NBG-460N I've borrowed from work:
I had to chuckle at Zyxel sticking a Gigabit WAN port on it.
My rather old (at least 5 years) but trusty SonicWall TZ150:
Will see what others routers I can find to test but I can see FTTC/P causing a few headaches when it shows a lot of routers aren't up to the job.
