1440 monitor for a 970 - advice requested
29 Apr 2016
Hi all, read a lot of threads and realised I know nothing so thought I would just ask for direct advice.
I am currently running a GTX970 with an old Iiyama ProLite E2607WS, which I inherited from an old system. I was considering upgrading to an ultrawide but am now waving over a "normal" aspect 1440 monitor as I read that the 970 tops out about this resolution for gaming.
I am going to be using the setup for gaming, mostly playing WoWs, Overwatch, D3, BDO and soon - No Mans Sky. Nothing competitive, just casual.
I have no idea on TN/IPS/VA or whether I want to run 144Mhz or not.. I am open to the wisdom of the forum on all these.
My budget is roughly £500.
What would you guys suggest? Any input is welcome
OP
29 Apr 2016
so I guess my next follow up would be - given the spec mentioned at the top (GTX970) what would be the best monitor if I didn't have a budget?
Just figuring if I am limiting myself to £500 but could get something significantly better for £650 for example would it be worth waiting til I have the extra funds.
