- 24 Sep 2007
Hi Guys
I have some old C# code that I wrote that adds data into a MariaDB using the MySql.Data.MySqlClient namespace.
The problem is I can't add text containing apostrophes into the database properly. I know this is a classic problem, but I can't remember how to fix it, apart from using stored procedures instead, which looks a bit complicated, especially when using MariaDB.
Anyway, my code, and in particular the SQL insert statement, is:
What do I need to do to be able to handle apostrophes added in the text fields?
Any suggestions or links to code examples appreciated.
Thanks
Code:
try {
// Open database connection
// Technique is passing the connection string to the constructor of the MySqlConnection class
// Note you have to import the MySql.Data.MySqlClient namespace to be able to use this
MySqlConnection conn = new MySqlConnection(connStr);
conn.Open();
// For testing
// lblMyTestLabel.Text = "Connection Opened!";
// Get values from web form
String BrandName = txtBrandName.Text;
String BrandDesc = txtBrandDesc.Text;
String BrandUrl = txtBrandUrl.Text;
String BrandPage = txtBrandPage.Text;
// Add the brand
String SqlInsert = "INSERT into brands (BrandName, BrandDesc, BrandUrl, BrandPage) VALUES ('" + BrandName + "', '" + BrandDesc + "', '" + BrandUrl + "', '" + BrandPage + "')";
// Create a command to run against the database
MySqlCommand cmd = new MySqlCommand(SqlInsert);
// Specify the CommandType for the connection, in this case it's text from a string, not a stored procedure
cmd.CommandType = System.Data.CommandType.Text;
// Give the MySQLCommand a connection to use
cmd.Connection = conn;
// Execute the non query
cmd.ExecuteNonQuery();
// Close the connection
conn.Close();
// Hide the form
formBrandAdd.Visible = false;
// Confirm done
lblUserMessage.Text = "Brand added! <a href='brand-add.aspx'>Add another</a>";
lblUserMessage.BackColor = System.Drawing.Color.LightGreen;
//For testing
// lblMyTestLabel.Text = "Yes, that's completed! <a href='brand-add.aspx'>Add another brand</a>";
// lblMyTestLabel.BackColor = System.Drawing.Color.LightGreen;
Thanks
