- 25 Oct 2018
All pumps have a failure rate of some kind.the
Aqua Computer ULTITUBE D5 200 PRO RGB Pump / Reservoir Combo but ive read a few threads on the net saying the pumps dont work as well some say they fail like most others as well but since you have one have you had any problems as i need a bigish one as i have the phanteks elite case which is big and not only that i like the look of them ive had ek they just look plain and simple i know they work ok want to try something new
They're ******* awesome.
I have the 150 myself - It's basically a mini Aquaero.
What are you specifically looking from in a pump/res, or by what would you define 'good'?
^That's how I do it.However, I'm wondering if I could run a USB cable from the Utilitube to the motherboard just to report pump and fan speeds and temperatures?
Values can be reported in HWInfo, Aquasuite itself, or anything similar.
You can use the D5 connected via USB to read any other sensor. So you could run a ¼" fitting temp probe from your Mobo 2-pin header to a Rad port and measure the delta that way... or a standard probe and measure ambient temp delta... or any other compatible sensor, such as a flow monitor or a waterblock (mine has one) with temp sensor.Thanks for the clarification.
Having looked through the manual for the D5 Next I see it only has one temperature sensor which is obvious when I think about it as the temperature of the coolant isn't going to change at all between in and out of the Utilitube, doh!
I think I got confused with my previous setup where I had a sensor fitted at both the in and out of the radiator. With the new build and using the D5 Next only, there can be no fan speed control based on that delta, just on the coolant temperature of the Utilitube. Unless I decide to use my Aquaero after all.
I might also argue that temperature variance between components is not that useful, as the temperatures should pretty much equalise throughout the loop, with only a couple of degrees difference at most between points.
IIRC - Water temp, Software temp, Fan voltage, pump voltage, +5V, +12V, pump RPM, pump power (watts), and flow in LPH.The manual for the D5 Next is a bit scant on details, but what precisely shows up in AIDA64 or HWInfo for the D5 Next? I'm pretty sure it's pump speed, fan speed and coolant temperature; my googling of the subject brings up a mixed bag of information.
Question. im looking at this pump combe, but i want to mount it to a 120 x360 rad.. is there a mount for it..
