- 19 Jun 2012
Hi all
We will be refurbishing our bathroom imminently and I have a couple of questions regarding soil pipes.
Currently, our house has a soil stack from the ground floor kitchen and it passes vertically right through the house and it vents out of the roof.
The pipe passes through the corner of our bathroom, which is very modest in size and we are losing almost 1sq/ft to the boxing in the corner that houses the soil pipe.
My question is does it need to go through to the roof and vent externally, or can I:
Additionally, if this is possible, what is the correct height from the junction point for toilet and basin wastes to install this? Ideally, to create a seamless worktop on the vanity units I would like to bring the whole soil pipe section (including waste junction) to around 840mm high. That would allow it to sit below the level of the worktop and have a 12mm clearance above it.
Does anyone know what sort of clearances these air admittance valves require?
I would greatly appreciate your advice.
EDIT - added a basic picture to try and make sense of my descriptions!
- Cut the soil pipe below roof level in the loft space and cap it to prevent water ingress (saves me having to mess around with the penetration through the roof which is currently water tight)
- Remove the section of soil pipe from the bathroom junction up, including the junction itself. Then install new junction and a short piece of soil pipe and cap it with something like this http://www.screwfix.com/p/mcalpine-vp100n-solvent-weld-air-admittance-valve-grey/6047p
- Enclose the area with some timber batons and a choice of finish, incorporating it into our toilet / basin vanity unit design so that it remains concealed.
