Hi, changing kitchen appliances.
We are changing the Extractor hood.
The new one has the ability to recycle the air. What is the best way of blocking the excising holes?
ALSO, Bit of a problem. The new Extractor Hood Height, is less than the old one. So I need a way of covering up some of the bottom when I mount it.
ie: (bottom photo) the new hood when fitted to above kitchen unit. The bottom of Fan unit, will then be level with the Bottom row of screw holes in the photo. Hows best to tidy that up.
I was thinking expanding foam. Then maybe smooth over with plaster?
Thank you
Thank you
