- 7 Jul 2023
- Leicester
Been a long time coming but seriously considering going down the custom loop route in the New Year on my main rig. I may have to buy a new case as well & if that was the case, I would have to look into options, but for the moment i just need suggestions on the core components required for the loop.
I would be looking at a soft tubing setup to start with as I just don’t trust my precision measuring/cutting skills with hard tubing, although I would not rule it out at a later date so would like the option to swap over to it if I decided to go for it in the future. i don’t need anything fancy as won’t be having any RGB lighting etc in the system (I hate it & I prefer to look at my screens than the insides of the PC). All I am concerned about is the overall cooling of the solution.
CPU - i9 13900K
Motherboard - ASUs TUF Gaming z790 Plus WiFi D4
GPU - PNY Uprising XLR8 RTX3080ti
Current Case - Lian Li lanCool II Performance Mesh-C
What I would like is suggestions for water blocks, radiator (not size as may need to change case so internal space depends on that), fittings (just brand & type of them as obviously would depend on tubing route, case, etc), pump, reservoir, tubing & coolant (as well as anything I may have missed).
I would be reusing my Noctua fans I already have as well as adding any in if needed (4 x 140mm & 3 x 120mm) & have plenty of other fans of both sizes sat on the shelves to use temporarily until i can get any additional Noctua’s should I need them.
If I need to change case, then would prefer one with the least amount of ‘window’ as mentioned, I won’t be looking at the internals & if I do I can take the side off.
Any suggestions would be appreciated as don’t want to fork out on anything to find out that could have done better for less money or if had taken something else in to consideration.
CPU - i9 13900K
