Hard line water-cooling set up help needed
21 Apr 2010
Am looking to hard line my set up but i wont be heat bending the pipe. Will be using joins can someone with experience in this have a looking and tell me what type of connections i will be looking at please. gpu blocks coming next week. Will be looking at 13/10 connections
This kinda joins between the pipes
With thanks
Did the same in a build recently ( more info in the link in my sig ) using 12/10mm
You'll need 90 and 45 degree male to male hardline compression fittings for the bends.
I recommend these, by Nanoxia, as they are a much cheaper than most - £5 each compared to £16 each for Bitspower !! :
Coolforce Hard Tube Adapter 90 Degree 12mm to 12mm OD CF-MGF190C
